Ah, thank you! I input the dial code and I have an “apps” tab which has magisk on there. I put this dial code as a note in my phone so I will know how to view my apps again when I need.
Also, would there be any way I could run Discord on the TCL Flip 2? I know the Kyocera 903/902 KCs can run it, which means the APK exists out there somewhere, but from looking at the dumbphone subreddit, it seems that only Kyocera 902/903 KCs can get it to work properly. I could be wrong though. I’ve also looked on here for APKs and there’s nothing about discord or waze. So it probably doesn’t work, but I figured I would ask
hmm… I wonder how big a pain. Because even just seeing who’s online would be useful to me. Seeing who’s online on discord is a good indicator for me of who of my friends has free time or is home and off work. If I installed the optional mouse cursor from the guide do you think it would still be terrible?
On the home screen of the phone you should be able to press the up button and it should open apps up.
Also waze definitely works on the phone. You should get The mouse it makes everything more useful.
Is there a way to sync and/or bulk transfer google contacts to a TCL Flip 2? Also is there a way to get a better t9 dictionary / be able to add words to the dictionary?
in the manual on the TCL website, it says that you can use the import/export feature from a memory card, bluetooth, gmail, etc, but the only option it gives me on my phone is to/from the SIM
