Tiq Mini M5 General Thread
I am getting such mixed vibes about this phone. Please share your experience below. Hardware, software, service in the US…
Thank you all!
Is cdmaless mode required for Verizon to work on the tiq mini m5?
No but you need to activate in a different phone in order for Verizon to work
Are you sure?
I’m pretty sure there were many times where Verizon was already a registered SIM card and needed to turn on CDMA less in order it for it to work on the phone
As of my experience you don’t need it
But a friend told me that he needed CDMA less
So I guess it’s hit or miss
Could we accomplish this for the Tiq?
You would probably need to get carrier approved like the F30
So it has nothing to do with something baked into the rom like it looks like in @farrict’s post?
It’s simply a registered device that is cdmaless so us mobile puts it on by default just like some pixels?
That’s what I would assume
I have a custom rom for the M5, I needed to make some edits to the system apps so I unpacked the super using crb kitchen. I made the edits and repacked everything using Sparse Image. I originally tried making edits to an app in the priv-app folder but figured out that can cause some problems so I reverted back to the original app there.When I try flashing the Super via fastbootd it flashes successfully and partially boots then goes into recovery and says the system is corrupt. Any ideas on what I am doing wrong? I can flash the old super and it boots totally fine. The only thing I am doing is replacing one apk in system_a\system\system\app.
Edit: I finally went to an older super and modded it to what I need it works, so something must’ve been wrong with the newer super.
they are not carrier approved
there is something baked into the rom and they add an antenna
not always sometimes it needs cdma-less
I have t mobile us mobile on my tiq. It’s been working great for the last few weeks. Today out of random I can’t send sms or mms. I can receive calls sms mms and call others. Data works as well. Any ideas?
I tried restarting a few times but it didn’t help.
After switching the APN and then restarting it started working again!!!
And boom it randomly stopped working again!
I switched back the APN to default and then back to the one us mobile provided and it started working.
Pretty annoying. Could this be cause of the IMEI?
Would it help if I switch the IMEI to a cat phone imei which is t mobile?
@Yidish ever had this?
Did you call your service provider ?
Yes they said that everything looks good on there side.
What’s the process to change the imei on the tiq?
Can I use the exact instructions for the F 30 like all the files?
5 posts were split to a new topic: Weird Bug On the Tiq Mini M5
I flashed newest firmware.
Unlocked bl, flashed disabled vbmeta.
dm-verity corruption, no matter how I flash.
Help? First experience with this phone
You’re supposed to use firmware upgrade in sp flash tool.
And about the bootloader I kept it locked and it updated.
Look at the word sheet in the zip folder of the update.
