The method i use to remove the browser, sms, gallery…
adb shell
su
mount -o rw,remount /
rm -rf /system/app/FileManager
rm -rf /system/app/JrdGallery
does not work when i try to remove QuickSearchBox
rm -rf /system/product/app/QuickSearchBox/QuickSearchBox.apk
i get a read only error
when i try to remove from the phone itself using root explorer it works without issue
P.S. i have no idea what the quick search does it just looks scary when youre giving someone a filtered phone and they see something that says google search
Sorry i dont really get the whole back and forth! (i hope its all in jest). but my question remains is there a reason why davka this app wont remove with the standard commands. ( i already have an alternate solution but id rather not have to install another app … and then remove it before handing over a filtered phone.
(also as an aside what exactly is neutrons recovery image is it a super with some special features)
Looking forward to your ROMs
If you want to just disable it on the phone: pm disable-user com.android.quicksearchbox. If you want me to guide you on how to remove it from product using Neutron Scott’s recovery, let me know
If it doesn’t take much time i would appreciate a guide using netrons recovery. but not an emergency i have it figured out another way.
is there a simple way to pull a rom off a phone once i have it set up the way i want and then just use that to set up other phones
