I asked “which features are you excited about?'”
It’s not about a specific feature, it’s about the idea!
ווער ס’פארשטייט פארשטייט.
איך פארשטיי נישט
What is not understood? Jelly Star is a very good and compact device, and it is very comfortable
And after the update to Android 16 it will probably be faster and with a nicer ui
Jump from Android 13 to 16
(Every word is redundant)
ver hot gelacht??
Yup Totally
have you ever felt the jelly star?
it’s not.. that makes sense, if yes then something’s off,!
Any battery performance tips? My jelly star has been going recently from 100% to 40% in an hour, never been like that
I have a Titan pocket, and it wont connect to mobile data.
I’m using a us mobile Verizon sim and it reads the phone number, but doesn’t have reception.
I tried all apn settings still not.
I sent it in to a repair store and they said its in lemon condition, meaning its a defected phone,
I’m still convinced that it is a software issue; but it makes sense that the cellular antenna is at fault since it doesn’t even search for available networks.
if any one had such problems, or knows how to fix it pls lmk. thx
Maybe it’s a CDMA problem. Call them up and ask them to enable cdma less mode.
If it doesn’t even search for networks its not a CDMA issue
You find any solution for it meanwhile? What SMS app your using rn?
I think using a google messages version from September (2025) will fix it
U think?? I mean I had this issue even back then?
Google messages broke Multimedia Messages on the Jelly Star around December time, so try going from November versions (or even earlier) and see which is the latest version that doesn’t have the MMS issues
This was written back in March '25
He’s not talking about the MMS issue. Its another issue (which idk about) he’s talking about something to do with voice notes
Are you talking about that issue or the issue with picture text (aka MMS) not working?
He talks about 2 problems: 1- not being able to download (listen) to voice notes 2- images are received low quality (almost sure that’s what he meant)
I have both issues also I can’t connect to Google messages integrated system aka RCS chats even tho the connectivity status says it’s connected
Did you try this?
Was this update ever released?
