Verizon MMS protocol issue (voice note/video not playing)
As you guys know already that Verizon customers who are using an unverified device are having issues with listening to voice notes and compressed images. Besides if they are using Verizon messages app (Message+).
In my case I’m using the Unihertz Jelly Star phone and I want to use Google messages, so is there any work around to spoof the phones identity, that Verizon should think that I’m using a verified compatible phone? (Just changing the IMEI, isn’t the solution.)
Question has has been answered already use handcend app
Question was NOT answered already!
I didn’t asked for a app that doesn’t have that issue.
I asked, if there is a way to make it work even using Google Messages.
No there isn’t a way to do that (not as of yet)
The phones mms-user agent is written deep in the phone, not so easy to change.
(There is a magisk module out there that spoofs any phone to the galaxy s24, however its risky (if it would work even for this issue) and i know someone that bricked a device trying to do that.)
Does your friend know what he is doing?
Do you have the module by any chance I’ll try it
He installed it via magisk and rebooted it’s not that complicated.
His phone screen didn’t turn on after it rebooted, he had to reflash a rom.
It was tryed on a qin and bricked it, for your own sake don’t try it. (U wouldn’t be the first…)
I tried it. it didn’t work
@ars18
hi
i see that the tiq mini m5 has the same problem with Verizon voice notes,
can you tell me how you have fixed it ?
is it because the file is QCELP?
@yossii check this out.
Thanks I’ve checked out the conversation but I didn’t find any solution there
If you know how to decompile roms try to figure out the fix from 613
What’s the solution?
to use t mobile :laughing:
Would love to see a solution for compressed mms images on Qin (using google messages with us mobile / verizon).
I’m using 613 - don’t see this fixed. (Am I missing something?)
Huh. The 613 is supposed to have everything fixed.
PS did you need to call up about cdma less mode?
I guess I am. Voicenotes work fine for me, but many MMS images come in too compressed to read text.
Aderaba, if anyone can help, it would be greatly appreciated.
PS yes.
PPS they said it was already enabled.
PPPS so i guess I didn’t really have to in the end.
PPPPS so delete the first PS.
Even on T-Mobile and many different phones, mms images are blurry and hard to read text…
If you download to gallery it comes clear
Ur :100: correct, his rom only resolves Verizon voice notes MMS and we appreciate him for that, however, Verizon mms images are still compressed and blurry.
Just curious does the F30 have the low resolution issue?
