Unlocking Bootloader Issues on Qin F21 Pro
How do i unlock the bootloader so I can flash an unsigned ROM (Ashi’s Kosher ROM)? What partitions do I flash in order to not mess up the USA bands that are on it?
The band partitions are nvram nvata nvcfg
Md1img
You’ll need to flash a stock boot image and click try again from Android Recovery. https://limewire.com/d/bmklQ#zOobxxvcrT
I went onto MTKClient and pressed Unlock bootloader. Now when I turn on the phone it says
dm-verify-corruption
Your device is corrupt
Press power button or device will shut off in 5 seconds
I pressed the power button but the device just shut off
What do I do?
I tried locking the bootloader and now it doesnt even turn on
I’ve gotten the same issue. Do you have a stock backup? If not I can send you one. I had to restore the stock backup, unlock the bootloader with the tool linked on XDA, and when I flash 1.1.1 with SP Flash Tool, I didn’t get any more errors
Can you send the stock backup
So I shouldnt unlock the bootloader via mtk client??
I think once your on stock you can do it in MTKclient as well. the tool uses mtkclient to unlock it (its basically a wrapper script)
Is this the stock? https://forums.jtechforums.org/t/f21-pro-stock-rom-signed-no-gtr/201?u=donbot
Seems like it should work. If its signed it can be flashed onto a locked bootloader
I know, but for some reason MTKClient gave me a dm verity error (which flashing an empty vbmeta didn’t help on a modfied super) which the tool didn’t give me.
After running the tool, I got an Orange State error, but the phone booted. After flashing 1.1.1, I didn’t even get an Orange State error
I tried that. Didn’t work for me
Can you send the stock?
Privately
This is stock
You could try it, but when I had this issue, this didn’t fix it
i had to do the 1.0.8 one and then it worked
I have had the same issues steps to fix are:
flash stock (make sure to press format and download)
unlock bootloader with mtkclient
flash android 1.1.1
should work
this works and restores your device if you flash with sp flash tool on format and download.
