Sholom Uvrocho, im trying to unlock a tlc flip 2 (T408DL) KEFS , with hardware version 03 which seems to have a KosherTek filter on it. I have sent my imei to my carrier and have received the 2 unlock codes but when i put them in after typing #tfunlock# it says the codes are invalid. Is this because its using KEFS? I think i saw someone write on this forum that there is an easy way to unlock it if it uses KEKA? If I flash KEKA would it then be possible to unlock? And is it shayach to kasher easily after flashing KEKA? any help would be much appreciated
here is where i saw this unlock method:
and
many thanks for the response. Can you think of any way i can unlock this device since its not because of KEFS? I guess if the issue is that the device has a kosher ROM, if i flash stock, then i can unlock and flash the kosher ROM again after that?
If the issues with the codes is the kosher Rom then Yes if its not blocked
We don’t talk about flashing pre kosher phones here
