As always remember mod at your own risk. I take no responsibility. You may brick your device.
Use the software for your device, so far I have uploaded for KEKA and KEFS.
This is only intended to work on a fresh install. Factory reset before installing. (If you are starting from scratch unlocking the bootloader will do this either way.)
Main: Removes: Browser and Hotspot. Adds: Mouse, Voice Access, Waze, Weather, Siddur, Zmanim, Smartlist, Hebrew T9.
NoMlVd: Same as Main just removes Email and Video.
NoTxt: Same as NoMlVd just removes texting.
Thank you so much!
I don’t see any different apps than the apps4flip Rom. As someone who knows the TCL and your previous Rom inside out I would love if could you give more information on what you changed.
Here are my questions.
Is there a new call log app?
Back app?
WiFi calling added?
Same weather app as latest apps4flip? (that one was terrible so was the one from the first version).
mouse v2 or 1? Is it a script or a special boot like the first version on apps4flip?
Black bar removed from added apps? Siddur needed it since it blocked words.
Smartzmanim?
Microg?
Hebrew t9 Is traditional t9?
Would these work on kefh with flashing the network partitions and empty vb?
Is this what you sell?
Thanks in advanced!
This guide should be added TCL ROM Flashing Guide for Windows
one more thing should be flashed which is keka/kefs boot image fastboot flash boot KEFS/KEKA_boot.Img
External emergency dial goes home. As does *#*#123#*#*
Yes
Original one. If you have a better one please share.
Custom mouse, script, not built into boot but needs the boot to run.
No, Siddur can resize the text to help with that issue.
Yes
No
Yes
Probably, although I would suggest flashing all updated partitions. Maybe @TripleU can make a guide with his pulled KEFS partitions on how to manually update a phone from KEE7, KEEZ, or KEFH to KEFS by flashing partitions.
Hi,
Please let me know if I am in the wrong place…
I need a “home phone.” I don’t want anything other than calling. I have a TCL4080DL. Which ROM should I use? In the past I used the ROM on apps4flip with the guides followed to the t and it worked. Im a little confused here…
Whadda You know. My TCL is Keez! It’s been sitting in my house for a long time (unopened).
Guess I’ll hop back on to Apps4Flip. I assume I can use all the updated prereqs from this site?!
