I have US Mobile T-Mobile on my Qin and service doesnt work does anyone else have this issue?
Just change to Verizon T-Mobile is not good on the Qin
Verizon doesn’t work well group messages and voice notes and videos.
Was wondering if anybody else has this issue?
Old issue.
use message Plus systemized…
For tmobile service?
US mobile T-Mobile network worked great on my qin everything worked perfectly from the service to voice notes to RCS messaging I didn’t have any problems
I followed the guide on xda is there something i did wrong?
You said Verizon, hence I responded to use message Plus, did you mean T-Mobile and type Verizon by mistake?
Did you put in the correct us mobile light speed APN?
No i meant tmobile
you prob. just flashed the bands (or got it flashed), i had this problem and i flashed the whole phone ad it worked ![]()
how can i add a apn by me its greyed out
Us mobile once gave me an app because I had a Samsung with this issue call them and ask them if you don’t figure it out I’ll try to look into it tomorrow iyh no promises
for some reason if you use verizon it is grey…
By now do you know how to solve US mobile issue?
@yossii did you flash only the bands?
Look for the 6.1.3 rom and try that.
which carrier
Verizon
Yes CDMA less is the fix
This is not true if you flashed it with the USA bands it will work well
