I tried pluging a USB into a Android device using a c to USB adapter. The USB didn’t show up on a file manager. Is there any way to get it working?
Which device?
Does it support USB OTG?
Nothing specific
I’m not familiar with that, how do i check?
nice memory ![]()
daemon started but it couldn’t detect the device. Could it be because could be it doesn’t support usb otg? Don’t know much about usb otg…
Which phone? I’ve only tried on OnePlus 8 and OnePlus 12
Tcl and tried on mp3
I doubt those support USB otg but who knows
so you hold it needs usb otg?
What about qin does it have otg?
anyway to add it?
@ars18 it seems like there are magisk modules to enable USB otg. Any you recommend?
Don’t know anything on the subject
Just tried on the qin it worked and usb otg file explorer worked. Still looking for away to enable USB otg on the tcl, if anyone knows of away…
Probably not possible, its a hardware thing.
The USB port has to support USB OTG, and most flip phone’s C port don’t support it.
Wouldn’t be the port it would be the kernel which most probably is the problem though I am in middle of trying the guide on xda just in case its a permission issue
Fine.
Go argue with Google.
Do you think it makes sense the c port could export tons of data put cant import? Its something deeper…
Trying to understand how you answered what I said:
I know that its a fact that there’s such a thing as a port’s hardware itself not supporting USB OTG.
Not because I understand why, but because it’s been said by people who understand these stuff better than anyone in this community.
If you want to understand the how’s and why’s, feel free to ask ChatGPT, but your svaros aren’t going to change the metzius.
