Verizon Group Message and Picture Issue on Qin F21 Pro
Depending on the messaging app. On some double, On some no incoming MMS.
Have you selected the right network setting in the hidden menu? And right after restarted your phone?
This is what its always been on.
Now turn off the phone and when back on go to regular network settings and select LTE/GSM/UMTS and then check of it works
As I mentioned before, under regular network settings, There are only these options:
Is it a tracfone/total wireless mvno?
I’ve noticed that these carriers don’t allow selecting lte/gsm/umts in regular settings
Yes. Safelink.
And which messaging app are you using?
Currently, Handcent Next SMS. Only have the issue that in group chats, I get my own text sent back to me. It also fixes the MMS quality issue somewhat.
but I was referring to other apps such as google messages, and Textra.
By the way, Handcent sms won’t receive all texts unless it’s a system app
Have you spoofed the mms profile in handcent sms settings?
Of course. And its systemized. Been using it for years now.
I say use message+ to not face this issue, it’s the only legit solution for Verizon MMS
There has to be an app that works that fixes all the Verizon issues
My friend has the f30 and some how there’s a message app that works with Verizon and has no issues what so ever
Does anyone know which app it is?
It’s one from that company EKO
They use an old version of Google messages
So how do they make it work?
And that works just fine?
They probably spoof the mms-profile-user-agent on the device itself. (Eko f30’s)
Which is not a process that can simply be done.
I spoofed the mms user agent with a verizon samsung profile and it didn’t help, there are probably other user agents that need to be spoofed
