Verizon Group Message and Picture Issue on Qin F21 Pro
I use it with US Mobile under Verizon network and I always have five bars works perfectly
Do you have the video texting issues?
Yes video and audio but that’s all
And it’s only with Google messaging Verizon messaging it works perfect
By the way if you have a solution let me know
I’m on T-Mobile with RCS everything works perfectly. Even if you don’t have RCS
Thats probably why he highlighted it as Verizon specifically
Does anyone know how to fix problem with mms on g messages on qin f21 pro?
Check this out:
That doesnt help the issue tho
No fix for Google messages+Verizon
THANK YOU!!! I have the Unihertz Titan on Visible. Using the MBSmart filter. I couldn’t get MMS and RCS messages. I tried everything and gave up! started using Textra…
Then I came across your post. I tried it, BAM—instantly RCS started working, and so did MMS!
Ever get anywhere? For the voice notes
6 posts were merged into an existing topic: Flashing US Bands and Putting Play Services on Qin F21 Pro
