Voice Access on Kyocera DuraXV E4810
While on the topic of voice access.
On the LG Classic the Voice Access seems to readout every call even on silent and after picking up the call. I saw over here they meantioned to run a select command to disable the readout. Just curios, in this post what does one accomplish when running it with
the -k --user 0 vs without it?
Unless theres a version that has that issue fixed?
-k : Preserve app data on uninstall
--user 0 : Apply command to primary user (without that would apply to all users)
im new here just wondering did you ever figure out a solution for the kyocera dura xv e4811?
Yes
https://www.jtechforums.org/t/voice-access-on-kyocera-duraxv-e4810/381/18?u=flippy
This one fully works with the ok button?!
yes
Worked perfectly.
Yup for me to… Thanks btw how did you make it? Is it just a newer version of the app or there’s more to it?
Didnt make it. See above who modded it.
For me Kyocera e4830 if you turn on mouse then you could tap where the okay button should be but you can’t see it
if you could put it into dark mode (by using the mouse to double tap the top bar and then going to quick settings) then you can see the okay about them and you can tap it with the mouse.
What phone is the e4830? Are you using the one i posted?
Basically the same phone just built for AT& T
The xe epic?
Yes
