Was this discussed? Where can I find info on...?
New users will sometimes refrain from posting because maybe it was discussed already.
The search engine here is not the best in my opinion.
So here’s a thread to ask if something was discussed. Someone who wa here for a while and remembers things will hopefully help out.
#Letsseeifthisgoesanywhere
I reset my Qin f21 pro and it went to some sort of settings screen and I was playing around with it and I pressed on something I don’t know what and now when I turn it on it goes to the duoqin startup then goes black and keeps repeating. Is their any way to fix it?
Ask over here Qin F21 Pro Topic
Try resetting via recovery use autobooter then run fastboot reboot recovery then if that doesn’t work flash stock rom with sp flash and select format+download
Just a suggestion maybe integrate an AI search/ chatbot into this site
Happy to help with development if needed
@anon97982153 @TripleU
There was a hacked version of mt manger that @tripleu posted that windows defender found a virus.
I remember a website or app that @Dev-in-the-BM_2.0 posted that have you group me bots anyone know what I’m referring to
where was kyocera sending random messages thread
@sams-club Kyocera Randomly Sending Old Messages
How do I get into recovery on the Qin F21 pro?
I’m trying to unlock a Qin F21 Pro and flash 1.1.1 on it.
I’ve seen a lot on the forum about the Qin, but have no idea where to look.
Where is @TripleU ROM for the qin f21
It was taken down
@ars18?
Can we get it on DietDroid?
Never downloaded it. Dietdroid only existed after it was taken down.
