where is the repo? @ars18 I can ask Claude for you
Wanna fight?
Fight what?
Automatic close. No time to possibly build the app and test.
And had you actually tried to build and test, you would notice that you canāt build it, and you would have asked about it.
Not trying to be mean⦠But.
Thatās fine. All I did was have Claude add one line of code because you said [quote=āars18, post:895, topic:5160, full:trueā]
Submit a PR, somebodyā¦
[/quote]
app/src/main/kotlin/com/jtech/zemer/ui/screens/OnboardingScreen.kt
adding the line
.verticalScroll(rememberScrollState())
Open PRās after testing is standard practice
I use AI, doesnāt mean I yolo.
I have no idea how to Build an app
I YOLO
Not on zemer ![]()
If you have 10 seconds btw can you add that channel
https://music.youtube.com/channel/UCL0auemfwJ0_Hp835-F9yPQ
It only takes 5 seconds but Iām busy ![]()
Fr though, remind me later and Iāll explain itās current state
I should DM you or ask on the main thread?
No Iāll say here
That way more people can gain
Btw @ars18 my offer still stands. Or if thereās anything else I can help with.
(Since it was brought up, The reason I havenāt even tried to make prās is because I think the project is easy beyond me at this point. You put in so much time and brains into this that to review it and find necessary fixes and test successfully would take years. Basic typical issue when someone else tries to contribute to a different repo. Especially when he isnāt as good as the original dev.)
My extent of helping would be YOLO which is not helpful to you
Still havenāt figured out what all this YOLO is.
YOLO is the concept of telling AI What to do and giving it full access
YOLO - You only look once
