Forgot Password on Sonim XP3800
I have a phone that I cannot unlock with device password.
I already tried with all the codes that I know, is there anything I can still do besides a hard reset?
I really need all the information from the phone.
Sonim XP3800
You have to delete a file called system/etc/locksettings.db
is it possible to do without root
Not really. TWRP etc.
What is TWRP?
Don’t know if this will be helpful but check this out:
https://www.reddit.com/r/dumbphones/comments/1ia45zl/cat_s22_flip_still_asking_for_pin_after_reset/
Thanks but no
Author deleted post
Is adb enabled?
Yes
See if adb backup would work
From recovery?
add it to your cloud and make a password resource
Its already on my cloud but it won’t sync
force a sync from the devices menu make sure your device battery is more than 15% and there is a data connection if its not syncing try to force a sync and then run the find my device command
When I said it won’t sync I wasn’t clear enough.
It won’t sync because I have no data connection (It’s a sprint model, I don’t think any sim would give me data)
try to use the T-mobile sim from us mobile (they don’t have a automated system that blocks service when a sim is inserted in a invalid device)
Right, but the data specifically doesn’t work
you can try contact them they can force a update without coverage
Are u sure about this?
of course look on their cloud website the last option
