How to Write the Perfect Forum Post
Learn how to write high-quality forum posts that are clear, useful, and easy to read.
1. Follow Proper Forum Formatting
A well-structured post is easier to read and understand. Use the formatting guide here:
:link: Forum Syntax to Make Your Posts Look Better
Some basic tips:
  • Use bold and italics for emphasis.
  • Use code blocks for commands and scripts.
  • Break up large paragraphs into smaller sections with headings.
  • Use numbered or bullet-point lists when explaining steps.
2. Set Your Guide as a Wiki
If you’re writing a guide (not a question or discussion), make your post a wiki so others can help keep it updated.
How to make a post a wiki (if you have permissions):
  1. Click the three dots (⋮) below your post.
  2. Click the wrench icon.
  3. Select Make Wiki.
:small_blue_diamond: Don’t have wiki permissions? If you can’t edit your post into a wiki, DM a Moderator to request a change.
3. Use Clear Language & Correct Grammar
A great post should be easy to understand. Follow these guidelines:
:white_check_mark: Use clear, simple wording. Avoid unnecessary jargon.
:white_check_mark: Check your spelling and grammar before posting.
:white_check_mark: Avoid excessive emojis, CAPS LOCK, or slang that might make your post hard to read.
Example of a bad post:
HELP!! my phone wont install apk can someone fix??? it says error idk what to do.
Example of a good post:
Problem: I’m trying to install an APK on my device, but I keep getting an error. The message says:
INSTALL_FAILED_USER_RESTRICTED
What I Tried:
  • Enabled Unknown Sources in settings.
  • Used adb install app.apk, but it still fails.
Device: Samsung Flip Phone (Android 11)
4. Be Specific & Provide Details
Your post should answer:
  1. What is the issue or topic?
  2. What steps have you already tried?
  3. What device/software/version are you using?
For guides, make sure you include step-by-step instructions so others can follow easily.
5. Use Tags & Categories Correctly
Proper tagging helps others find your post quickly.
6. Be Respectful & Follow Forum Rules
:white_check_mark: Stay on-topic – Don’t hijack threads with unrelated questions.
:white_check_mark: Be polite – No flaming, trolling, or rude comments.
:white_check_mark: Give credit – If you’re posting a solution from another site, cite your source.
7. Follow Up & Update Your Posts
  • If you solve a problem, reply with your fix and mark it as a Solution.
  • If someone suggests a fix that worked, mark their reply as Solution.
  • If new information becomes available, be sure to reply in the topic to let the others know.
:light_bulb: Need help improving a guide? Ask a Moderator or experienced user for feedback before posting!
