Forum Syntax to Make Your Posts Look Better
Here are some basic command/syntax you can use that will make your posts on this forum look much better
**hello** this will make the words inside the ** bold for example hello
--- this will make the all lines on top of this bold
___this will create a line good for making dividers inside a post for example
*Hello* this will make the words inside italic for example hello
~~hello~~ this will make the words inside crossed out for example hello
`hello`this will make a box around these words great for code for example hello
```hello``` this will create a box with a copy paste option great for code for example hello
[Hello](Basic batch script commands - Windows - JTech Forums) this will create a super link for example Hello
[spoiler]hello[/spoiler] this will make the words inside a spoiler for example hello
>hello this will make all words after in a block pls note that this must be used in the beginning of a line for example
hello
to stop words from being in the box simply create a blank line underneath
- hello
- hello
- hello
will create little circles before each line great for a list for example
  • hello
  • hello
  • hello
[color=red] hello [/color] this will switch the text color for example hello
[size=150] hello [/size] this will switch the text size for example hello
[highlight] hello [/highlight] this will highlight the text inside for example hello
\ this command can be used If you want to show a * but the system will trigger it as if you want to make it bold so you can avoid that by writing \*
you can hide details in a compact place - open to see how to do it
[details=“title here”]
put the hidden info here
[/details]
Hope this was helpful, pls feel free to edit/add more to this post
If this post was useful for you then pls like😜
Credit: @Biden2020Prez for making this thread on Apps 4 Flip
