Messed up storage
my tiq m5 is really messed up it says i only have 6gb left out of 22gb
now when i select all my folders and right click then properties it says that all the folders together are 1.20gb
so how can i get rid of all that garbage that i cannot find?
And Yes I Already Made My Pc Show Hidden Files
This is how much my Android system takes up.
Also, properties on windows will only show you internal storage.
Factory reset… You used ro2rw or similar…
yup i used ro2rw and now the phone and the actual root is out of space even though i didnt really do anything… now i really dont like the idea of a reset but if i need to do that how can i reset it and back up all my files and app data or theres no way?
Yoiiiiish… I factory reset it at least 3 times a day…
thats not an answer…:blush::joy:
