Root running out of space
I have a tiq m5 it says Im running low on space in root what can I delete to clear out some junk?
Already did ro2rw
Do it again every time you do it it gets bigger
Do I need to reflash it each time? Also any other alternatives
Yes needs to be reflashed or you could try crb*
Nah I’m looking for what I can delete… Will definitely do it later not I need space as soon as possible so again if anyone knows what I can delete I would appreciate it
This is the error from my manager
TAG: 2.14.5-clone-MOD-v6-xml-fix-beta-2(24011894)
PERMISSION: ROOT
ABI: arm64-v8a
Official RE-Mod by MT : true
MODEL: M5
SDK: 33
RELEASE: 13
TARGET_SDK: 30
—StackTrace—
java.io.IOException: Unable to open file ‘/system/priv-app/kosheroverlay/app/build/intermediates/compile_and_runtime_not_namespaced_r_class_jar/release/processReleaseResources/R.jar’: No space left on device
at l.ۘۚۖ.ۥ(Unknown Source:17)
at l.ۨۚۖ.ۥ(Unknown Source:54)
at l.ۨۚۖ.ۥ(Unknown Source:11)
at l.ۢۡۘ.ۥ(Unknown Source:162)
at l.ۤ۫ۡ.run(Unknown Source:296)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:487)
at java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
at java.lang.Thread.run(Thread.java:1012)
Caused by: java.io.IOException: Unable to open file ‘/system/priv-app/kosheroverlay/app/build/intermediates/compile_and_runtime_not_namespaced_r_class_jar/release/processReleaseResources/R.jar’: No space left on device
at l.ۨۚۖ.ۛ(Unknown Source:92)
at l.ۨۚۖ.ۥ(Unknown Source:28)
at l.ۘ۟ۖ.call(Unknown Source:10)
at l.ۨۚۖ.ۥ(Unknown Source:42)
… 8 more
Mount on Linux, and follow chatgpt to manually resize
