there is an app called Xdrip for diabetics that constantly monitors blood sugar levels. there is a transmitter placed on the body that sends via bluetooth the readings to a phone with the app
(this app is a unofficial app not made by the manufacturer)
i managed to install the apk on the TCL flip 2. but it seems like i cant see the notification that is asking to pair the bluetooth. it might come up as a bubble (thats how it works on Iphone) and i do seem to see something flicker across the screen but i cant see it.
any ideas how to see notification bubbles?
send the apk here and i’ll edit the strings to be a long paragraph of nonsense - so the ok to pair would be lower
im not sure what your going to do but i appreciate it here is the link
https://github.com/NightscoutFoundation/xDrip/releases/download/2024.09.17/xDrip-plus-20240917-dfcbe80.apk
the notifacation is from the app or the settings app?
here i edited every question - just randomly extending it - like "do you wanna sync with the other device etc. it should be a longer message dialog and you’ll see it - unless, again, the dialog comes from settings and not this app.
xDrip-plus-20240917-dfcbe80[2].apk (15.3 MB)
thanks so much for working on this.
it does seem like you did something the flickers i do see are a bit larger. but they dont last. is there such a thing as bubble notifications on these phones. in notification settings they are enabled. but whe i go to developer options the very last one is “bubbles” but when i enable it, it doesnt stay. when i come back to that menu its again disabled. i think this is where the problem might be. thanks again
Don’t know…
Did you try the app with a lowered dpi?
i didnt maybe i I’ll give it another shot
The notification to pair comes the the app or phone?
thanks everyone for your help i have since gotten it to work. it was just some settings within the app.
