On newer Android versions when trying to send more then 1 file via Bluetooth it doesn’t give you the option to send it so is there any way to bypass that block (trying to send 10 files to a flip phone)
I remember it being kind of buggy, but I think this works.
Didn’t work so I went to the next solution and created my own app for it it’s working great my app but I want to improve the UI before I post it
Anyone have a good name for the app?
And any other features that I should add to it bluetooth-related
MBFT?
Multiple Bluetooth File Transfer
What did you use to make it?
Bluetooth Unlimited
Aide
Never heard of it I’ll check it out
Here you go guys here’s BlueFlood
BlueFlood.apk (969.2 KB)
This will give phones that do not have the ability to send more that one file by a Bluetooth the ability to do so
Please note the app will only show you Bluetooth devices that you are paired to please pair your device before
Feedback would be greatly appreciated
For those who don’t know what the issue is here is a screen record
Great job on the qin on regular resolution its a little cut off and removes your credits
Wanna also post this in Android > Android Apps?
Did already…
I’ll try to lower the dp of everything later iyh but you can’t scroll?+?!
I’ll fix it but there’s no need for it on a tcl
Thanks @chatzie me created a lower DPI version
Blueteeth
Huh?!
Love this one.
