App Launcher for Kyocera Dura Extreme E4810
Does anyone know of a good app launcher for the Kyocera Dura extreme? Thanks!
Do you already know about the apps showing up in business tools? Is there a reason you want an alternative? What specifically are you looking for?
Yes I know that the show up in business tools but I want to be able to have them organized that’s why I want an app launcher
What’s wrong with the regular app launcher from apps4flip, it doesn’t work?
No it doesn’t work on the Dura extreme
I’m pretty sure the ‘simple app launcher’ works on the Kyocera duraxv extreme, apk can be found anywhere online
I have that one but it’s very basic and you can’t customize it. Do you know of any other ones?
What are you looking to do with it?
Use it for my phone?
Or if anyone has the simple app launcher with premium unlocked that would be great!
Meaning what features do you want it to have?
Oh nothing really just to be able to change the colors which requires the premium version
