Apps by @HalachiDev
there is some logic that it shouldn’reply to otp at all but I didn’t see a high success rate on it
A nice feature for the forwarding part of the app would be that the app reads your contacts and includes the name of the person that sent the message.
Would this app work for the exalt which runs android 6?
I am trying it should need only the minimum permissions
It’s build for Android 8
just enter the name
Does anyone have feedback?
Didn’t do any more testing after my initial.
Seems to work nice.
Had to allow most permissions by ADB, but I’m on Android 16.
Like I said, couldn’t change any forwarding settings after completing setup. Couldn’t get to the menu you referred to.
Otherwise, all good. Nice job.
Can’t you go to the three dots?
Did you tried to zoom in?
I don’t have those. That would explain it. Seems to be stuck on the status bar.
I don’t think most users of your app will be using it on fully updated Android version or my size screen.
Still, for debugging purposes:
wm size
Physical size: 1440x3168
Okay thanks for the screenshot let’s see what we can figure out for that
I played around a bit tonight on your app. Wow!!! You did a great job!
Thanks
Just a little question I didn’t tested the app on dumb phone’s before release.
just tried it…
Should I adjust the screens layout?
I only tried it on the Qin F21 Pro.
does it fit on the screen?
I just noticed that your app forwards MMS’s as well. I think that’s an amazing feature that other forwarding apps don’t have.
My question is why can’t the app forward a picture as apposed to doing this:
[MMS] [MMS - Media content]
–AutoSMSReply
What would happen if you mod it to work with android 6?
I personally only need the forwarding part for my exalt.
try to send something i dont think it will send the actual file just [MMS] [MMS - Media content]
Exactly. I just wanted to know why it can’t forward the picture itself?
probably its possible
but i didn’t had time to work on it
On the Qin F21 it’s pretty much perfect:
WhatsApp Image 2025-08-18 at 23.50.21_6548382c
Besides where it says “Auto SMS Reply” on the top left. It’s cut off a bit.
