Artificial Stupidity: Dumb things AI said or did
If Google Jules tells me one more time that
then I don’t know what I’m going to do…
Face with Steam From Nose
Sometimes, you hear something from AI so profoundly unintelligent, you wonder why it doesn’t run for office.
What are the most absurd things you’ve heard from AI?
Biggest head-scratchers?
Downright stupid advice?
Google Jules is like ChatGPT Codex.
It does it’s work in a VM in the cloud.
So when it tells me that I can access the webpage it just edited at http://localhost:8000, it’s like any other person telling me that I can access the webpage they just edited at http://localhost:8000.
It took up my dare.
Face with Symbols on Mouth
This is ridiculous, it asked me to check it’s edits at http://localhost:8000 another 5 times since then.
And it keeps telling me that it’s taking screenshots as part of its quality control process, to “make sure that the animations are working correctly”.
Please.
Tell me.
How do you check if an animation works by taking a screenshot?
I was trying to install something on Ubuntu, and was running into problems because it had a dependency that wasn’t available for the version of Ubuntu that I’m on, 25.04, codename Plucky Puffin.
I pasted the output from my terminal into Gemini, and it decided that the problem was that my system has my version set as Plucky Puffin, which it decided isn’t a real release, and I should change it to Noble Numbat.
Guess how much damage that would’ve done to my system if I would’ve listened?
Yep
Your link is not working for me.
By me it’s redirecting to showing Techloq blocking J-Tech
After Gemini Code Assist in VS Code messed some things up big time:
Enraged Face
I said don’t revert to the last commit.
Forgot “please”
And “don’t make any mistakes”.
That’s what the :-1: is for on the bottom left corner
