Specifically would like to know how the behavior of star differs across your typical usage of the phone.
What does this mean?
Sure I’ll try later send me a reminder
When you press the star button, it creates a button down event (and a button up event when you release it). Previously, the app was intercepting both events, preventing anything else on your phone from receiving those events.
The two fixes no longer intercept the button down event, but they do different things on button up that I want to test.
Seems to be great only tried 1
Only tested to see if the star works and also if the hold is the default
Tried the app on a att flip phone is great Works Amazon
Which phone do you have a little more information
Thanks for testing, if you find any bugs please let us know. Also, please use fix1 for now if you aren’t already doing so. @sams-club helped me verify a bug that is currently in fix2.
Do you have any update for android 11?
Have you tried the apk here?
If this doesn’t work I’ll need some time to implement what @Dev-in-the-BM suggested
Yes and didn’t work
The more information you can provide the more it helps because I can’t see what happened on your device and can only guess. Any description, screen recording, etc of what you are seeing?
I cant upload the screen record in the format it is
I created a guide to convert your file:
https://www.jtechforums.org/t/guide-on-how-to-send-videos-in-private-chat-on-this-forum/1107/2
The app doesn’t work on tcl
So zip it.
Can someone help test this debug apk on an Android 11 device that doesn’t work with cursor apps and is running Shizuku:
app-debug.apk (31.6 MB)
File size got a lot bigger but hopefully the release/final apk strips out the overhead.
Tried installing shizuku but got an error
What’s the error?
I have a filter in my device so it’s probably getting in the way but here’s the error
