Hi friends
As someone who loves programming and tweaking rooted devices, I know how frustrating it can be to rely on terminal emulators or shell commands for every little task. That’s why I created an app to simplify things. It doesn’t do everything, but it handles the essentials, including:
Backing up the super partition
Removing device passwords
Disabling apps like the Play Store or browser
Downloading useful tools like Magisk or MT Manager
The app works seamlessly with superuser/root permissions. If you’ve patched your boot partition with Magisk, you’re good to go!
Let me know in the comments what features you’d like to see added. Your feedback is appreciated!
TripleSU v.1..apk (4.9 MB)
v.2. update!
Hey everyone,
I’ve just released version 2 of the app!
The UI has been completely redesigned, and I’ve added loads of new features for you to explore. Check it out and let me know what you think.
If you find any bugs or have suggestions, feel free to share your feedback. Your input means a lot!
Enjoy!
TripleSU v.2.0.apk (5.0 MB)
v.2.3 update
V.2.6
FIXED EVERYTHING
https://drive.google.com/file/d/1o98Zl7mcbKws_Dvq58-H7Yhf_SsGKq_O/view?usp=drivesdk
Looks great! I downloaded it on my TCL.
Can you make a guide for dummies what all the stuff do?
PS When I press the Jtech Forums I get a list of different options what to open it with, what do I press?
Oh I don’t have a browser. I thought you built it in to the app.
Hmmm… Nothing there is hard stuff. A quick AI question could fix it
What’s the speed up device option?
Ok. Thanks for mentioning.
I thought that someone who has root has access to some browser…
I guess I’m wrong.
I’ll update it when I have time.
Executes many optimization commands
I have a rooted TCL Flip 2 without a browser.
But will it mess up any apps?
Some apps when starting them for the first time ask for special battery optimization permissions, what will it do to those?
What will hide google play store do? Hide it permanently? If not what is the point?
TripleU
December 3, 2024, 7:19pm
14
Battery saver doesn’t have any effect on them.
TripleU
December 3, 2024, 7:21pm
15
Not disable, it still runs in the background. It’s just hidden from launching
So what’s the point? So people don’t chop you have play store?
TripleU
December 3, 2024, 7:23pm
17
Kinda. Also It should be able to run in the background.
Wow!!! What an amazing app. I installed it on my f21 pro and did the speed up option, it really works. How did you accomplish that?
sb123
December 5, 2024, 12:04am
19
How exactly speed up option work, I used it on a rooted f21pro
Are there any ‘side-affects’ if I use the speed up option?
Read through the thread it was discussed.
