I double checked the thread, I didn’t see it being discussed
been busy today on this. the version 2 is gonna rock
I’m on a rooted the device, the chase app worked fine, after I downloaded this app it said it doesn’t work on rooted devices.
(Luckily I deleted the app and restarted my phone and Chase started to work again)
Can’t wait!
UPDATED!!! check it out
This is the screen that I get on the TCL Flip 2. Things are a bit cut off. I believe my resolution is 110 or 120 (default is 160).
What is the bottom right option?
terminal emulator
my bad, but i cant make one-fits-all —yet
gonna figure it out
Which does?
type a command and exectue
I can put in a adb command that I typically would need a pc for?
yes. just minus “adb shell”
updated!
Android 10 and up ![]()
The TCL Flip 2 runs on android 11 ![]()
Odd. Don’t know. I’ll try today to change things around
this app wants me to allow all file access to it and i have mb smart and they dont allow me to give the app that permission any way to bypass that?
also maybe add names to the icons they are not clear to what they do…
