Custom Shell Aplication! TripleSU v.2
You don’t have to give permission.
(It’s only for Android 13+)
The app doesn’t shock you with anything. There will always be a dialog after clocking. So don’t worry
(Attachment screen-20241209-234416.mp4 is missing)
@sams-club it seems like you tried sending an attachment with “reply through email” and it didn’t work. We can’t view the attachment.
I don’t know what to tell you… Every time I open the app it automatically brings me to setting give all file access then it closes all file access and it shows the triple su app for a 1/2 a second then it closes…
I know I’ll upload it when I’m next to my computer…
I think the newest version will solve all of this
Which one is the latest? V.2.3?
Version 3 is the latest but I think he was referring to a newer version than both of them which wasn’t released yet.
the google drive link - 2.6
when hiding play store it will pop back up after a while…
That’s odd… Will look into it
@TripleU can you create a simple mdm with Switches on every android device owner api or just a text box to type a api and block it and then another one to unblock it
I can, but for 1k
As a bucher, i would do it for fun, but these days i’m very busy.
Also, Bug fixing and updates can steal the deal for me… it’s gotta be worth it.
but try Kdroid, or rather קיידרויד
Thats free and does the basics
k droid doesnt have half the features android has
Huh? :face_with_monocle:
thanks very cool app. now i uninstalled package installer (not realizing what it was… i would like to remove apps one at a time) how do i get it back. i cant install anything now
he created the app in a way that anything you do on the the you can reverse by holding down the same button for example if you pushed the button that hides google play store you can reverse it by holding down the button that says hide google play store
i used the hide apps feature. and the apps would not come back even after i hit the unhide option
Try to reboot the phone
i tried it didnt work i just reset the phone and started from scratch
