Debugging on TCL Flip 2 KEFS
you have to put it back to kefh and update to kefs, then flash on the rom, you could also flash on the kefs version of the other partitions that are in the kefs update
thank you very much. but i’m going to need a stock boot img in order to unroot. would you have it. thanks
stock boot
Thanks a million
What other partitions are in that update? and is there a way to see what partitions were updated? i have a bunch of phones that were flashed with the wrong sw version ROM and now they dont call, (as expected). My idea was to flash all the partitions for the latest update of that phone but i have no idea which ones were updated
pull the update file after it’s downloaded and before it’s installed
i updated to kefs then flashed the rom it went thru the whole process 12/12 and completed but nothing seems to have loaded the browser is still there
Try again. I had to do it twice in the past when flashing a super (though I don’t remember if it said done the first time).
do i first have to flash neutron boot?
do i have to disable avb? ( i dont know what this means but its part of Darth instructiobs on app4flip)
i disabled avb and it works thanks.
can i install neutronscotts mouse. is magisk installed already (i dont see it in apps list)
It’s weird cause the instructions from @neutronscott on GitHub doesn’t require disabling avb (not that I know what it is).
Googling turned up that you need to disable Avb in order to flash customer roms. And it worked. I didn’t flash neutron boot image. now I’m not sure what to do about the mouse
just to update this: in order for the ROM to work you need to disable AVB. and in order to install apps you need to install neutron.img
alternatively you can download it elsewhere and Bluetooth it over
how do i update my phone to kefs from keez once the phone is rooted i cant update it.
Look up a few posts at this.
I got stuck and my phone is in a loop/bricked anyone knows what I can do?
Do
fastboot flashing unlock
And flash back stock
It says 'failed to write ’
Do you know what software version the phone was running?
