Does anyone have the kosher ROM for TCL FLIP 2 that was on apps4flip?
Or someone give me ADB commands to remove browser, and email, and update,
Thank you very much.
It’s not that simple you have to flash the correct boot image with fastboot and root the device first for adb to work.
(Apps4flip roms are out of date, therefore it may cause network issues depending on what software version you have and Waze doesn’t work)
Or you can use @NotABird’s kosher rom.
Thank you very much
I burn the firmware with SP FLASH TOOL?
Because I have NetFry filtering, the link to the ROM is blocked. Can you download it and upload it to a drive and send it to me?
Google drive is blocked by you??
Also it’s not my rom ask @NotABird
A link that appears in a public forum is blocked.
Copy&paste the url
This doesn’t help
Link blocked
That’s irrelevant, you would just flash the boot img with fastboot and the super with fastbootD, and some other fastboot commands in his guide.
No flash with fastboot
For now, it’s irrelevant because I don’t have the ROM.
The apps4flip one might not help you what software version is your phone
03
What software version not SVN
Where do I check this?
*#*#4636#*#*
Ok. Before you try flashing anything, go to software update and update your phone to KEFS
I’ve given up on flashing a version
Can you give me ADB commands to remove email browser and update?
Bad idea. You should use the ROM.
I could walk you through flashing the ROM, but you first need to update the phone.
Okay
