I need Yiddish T9 for TCL FLIP 2.
If you mean hebrew then get traditional T9.
Edit: In version 22 Yiddish was added thanks to @Darth.
Where do I get the traditional T9?
And how do I install it?
Are you able to install apps on your TCL?
Yes, because I filtered the device by the SUPER that is here on the forum.
So find traditional T9 APK online and use ADB to download it to the phone.
Can you give me ADB commands?
Traditional T9 is an amazing keyboard overall and works very well on the TCL.
adb install
and then drag the APK into the command prompt.
I don’t like it because it takes up half the screen
You can turn it off in settings
The link is blocked for me due to filtering
Can you send me the application by email?
Its on the forums search for hebrew keyboard in the uploaded apps thread
Try Settings → Appearance → On-screen Layout → Suggestion list only
For me TT9 is a great improvement from the default installed keyboard software that comes with the TCL.
As everyone else said: TT9
Great app that has Hebrew and Yiddish (which I added)
Very customizable to work on all phones, both in regards to physical hotkeys and display options.
What do you mean you added Yiddish?
It didn’t work with the cat… but it still is pretty good. Also, some ARMv7 devices don’t work with it…
I use TT9 on the cat and it works perfectly.
