Yiddish T9 for TCL FLIP 2
Interesting. I used all HW files from the cat - onto LineageOS 20 - and the tt9 didn’t work. So maybe I’m wrong.
How do I install this on my TCL?
Are you able to install APK’s on your TCL?
Yes, with ADB
So where you getting stuck downloading it?
I downloaded the latest version from GitHub and installed it with webadb and I don’t see the app installed on my phone. Do I need to grant permissions?
Are you sure that it downloaded? If you are using the app launcher then you may have to add it to the list to display it.
In webadb it said “Completed”, and in the application manager on my device I can’t find the T9 application to add.
you can dial *#*#217703#*#* to see a list of all installed apps
I don’t see the T9 app.
Its listed as TT9
nothing
Strange, maybe try using adb directly?
How to install with regular adb
Just because webadb says completed doesn’t mean that it actually installed
I tried installing with regular adb and this is the output:
failed to install D:\Users\User\Searches\Downloads\tt9-v49.0-full.apk: Failure [INSTALL_FAILED_INSUFFICIENT_STORAGE: Failed rename]
That means you have never rooted, without root you can’t install apps.
What sw version?
You don’t need to be rooted to install apps
What!? That is the error when not rooted
