eGate Remote Control
would love to see an online access option for egate so Someone can remotely control the filter
There are a million MDM products out there that do this and require a subscription. Mine does neither.
Are they compatible with flip phones, if so can you recommend one
I don’t know.
So after installing it for a family member, I realized every time they wanted something open they would have to bring the device to me. Which in a way is better than a filter that you call up every Monday and Thursday telling them you want this open, this closed. With this being a one-time fee versus all the other MDM out there with a subscription.
I didn’t actually try it but I would try to install anyDesk on the device and just log in using anyDesk to remotely control the device and open the filter and enable whatever is needed.
I’m just thinking out loud I didn’t actually test that but I don’t see why it shouldn’t work. That would effectively make the device remotely controlled.
i agree
@Flip2Talk Did you try it yet?
I will try tomorrow or sunday and let you know how it works.
So it works, but you’ll need to select the on-screen keyboard to manually input the code and have the otherside click enter. This way they dont see you inputting the code. As you’re typing it on your end. Besides for having a black screen so you would need to do it this way.. heres a picture of the black screen and which keyboard layout to choose on anydesk.
I ended up removing the filter from their device, only because they needed every Monday and thursday a new app opened. So had them go to one of tags filters. I think MB smart where you pay yearly for live support 24/6. Not a filter for them when you need stuff opened and closed all day.
But the anydesk app works. Just a tad buggy and you have to get the hang of it.
I think the best idea is for @FlipAdmin to just implement Remote Policy Change Approval | Voters | eGate
Yes and no, as I would potentially keep the App Store locked so they wouldn’t be able to install any additional apps.
For example I myself have teqlock so I have the access to the App Store which I can request any app I want, As well it’s great for the browser when I want to request any website that’s locked.
Just saying that if you’re using TeamViewer quick support using your own keyboard not the controlled phone keyboard the password won’t be visible
