Anything helps
What do you need? Besides for serial numbers
Dunno yet, firmware i have.
You can see how I’m organizing in
Maybe say the practical differences besides firmware, like
[quote=“dfrydman, post:80, topic:5277, full:true”]
also they changed the button for sp flash and sn write to the owl button not the backbutton
[/quote]
And if we find any more
im gonna be putting together all this info - but i have to go back to yeshiva so dont know when it will be ready
mine new one is a MQ and has a red port
Serial?
New speaker s/n f21pc25
Wrong thread, if it’s truly the second version of f21 pro, you can flash us bands, any old ROM, then apply speaker fix, search for my guide on the forum.
Or you can just flash 6.1.3 with all that included (gapps too), use snwriter to flash your info, and call it a day.
i did years ago i thought you wanted serial numbers
Oh. Whoops. Yes. Thought I was somewhere else lol.
This is the second version? 100 percent sure?
i needed speaker fix
Great, thanks for your help.
Another way of figuring out models can be the barcode that is on the label of the box. The label has a SN, IMEI, and barcode.
have another new speaker s/n f21pl24
Oh mannn… So either pl or pc
Both…
3/32?
3/32 or 4/64
both 32
is there any other info i could help with
Any of them stock? Aside from speaker fix.
Did they come with 33.2.1?
