no both were 2.0.8 one i flashed your 6.1.3
Israel?
ya
I have 3rd revision. Red port. 32GB. Serial:F21PMQC25
Perfect thanks confirms what we know so far
I donât know the revision. I havenât flashed yet (what is safe to flash ???)
Serial number
F21PMQC2511002753
Build Number
2.0.3
Orange Port
Is there a concise post that explains everything ? I havenât touched a qin in over a month
If you need more info i can go around my yeshiva checking everyoneâs qinâs
Serial number
F21PMQC2511002753
Build Number
2.0.3
Orange Port
I donât seem to have any of those issues described with v3 I have ADB and there is no device owner
@P9:~$ adb devices
List of devices attached
F21PMQC2511002753 device
@P9:~$ adb shell dumpsys device_policy
Current Device Policy Manager state:
Enabled Device Admins (User 0, provisioningState: 0):
mPasswordOwner=-1
mUserControlDisabledPackages=[]
mAppsSuspended=false
Constants:
DAS_DIED_SERVICE_RECONNECT_BACKOFF_SEC: 3600
DAS_DIED_SERVICE_RECONNECT_BACKOFF_INCREASE: 2.0
DAS_DIED_SERVICE_RECONNECT_MAX_BACKOFF_SEC: 86400
DAS_DIED_SERVICE_STABLE_CONNECTION_THRESHOLD_SEC: 120
Stats:
LockGuard.guard(): count=1918, total=20.1ms, avg=0.010ms, max calls/s=618 max dur/s=6.6ms max time=0.4ms
Encryption Status: per-user
Device policy cache:
Screen capture disabled: {0=false}
Password quality: {0=0}
Device state cache:
Device provisioned: true
@P9:~$
working twrp for new qin.img I got that from somewhere here i just cant find where exactly right now
Both of the above caused me bootloops
More info about my device: Can someone clarify which one it is ?
P9:~$ fastboot getvar all
(bootloader) max-download-size: 0x8000000
(bootloader) variant:
(bootloader) logical-block-size: 0x200
(bootloader) erase-block-size: 0x80000
(bootloader) hw-revision: ca01
(bootloader) battery-soc-ok: yes
(bootloader) battery-voltage: 4204mV
(bootloader) partition-size:sgpt: 8000
(bootloader) partition-type:sgpt: raw data
(bootloader) partition-size:flashinfo: 1000000
(bootloader) partition-type:flashinfo: raw data
(bootloader) partition-size:otp: 2b00000
(bootloader) partition-type:otp: raw data
(bootloader) partition-size:userdata: 6328f8000
(bootloader) partition-type:userdata: ext4
(bootloader) partition-size:vbmeta_vendor_b: 800000
(bootloader) partition-type:vbmeta_vendor_b: raw data
(bootloader) partition-size:vbmeta_system_b: 800000
(bootloader) partition-type:vbmeta_system_b: raw data
(bootloader) partition-size:vbmeta_b: 800000
(bootloader) partition-type:vbmeta_b: raw data
(bootloader) partition-size:super: e0000000
(bootloader) partition-type:super: raw data
(bootloader) partition-size:tee_b: 800000
(bootloader) partition-type:tee_b: raw data
(bootloader) partition-size:dtbo_b: 800000
(bootloader) partition-type:dtbo_b: raw data
(bootloader) partition-size:vendor_boot_b: 4000000
(bootloader) partition-type:vendor_boot_b: raw data
(bootloader) partition-size:boot_b: 2000000
(bootloader) partition-type:boot_b: raw data
(bootloader) partition-size:lk_b: 100000
(bootloader) partition-type:lk_b: raw data
(bootloader) partition-size:gz_b: 1000000
(bootloader) partition-type:gz_b: raw data
(bootloader) partition-size:sspm_b: 100000
(bootloader) partition-type:sspm_b: raw data
(bootloader) partition-size:scp_b: 100000
(bootloader) partition-type:scp_b: raw data
(bootloader) partition-size:spmfw_b: 100000
(bootloader) partition-type:spmfw_b: raw data
(bootloader) partition-size:md1img_b: 6400000
(bootloader) partition-type:md1img_b: raw data
(bootloader) partition-size:vbmeta_vendor_a: 800000
(bootloader) partition-type:vbmeta_vendor_a: raw data
(bootloader) partition-size:vbmeta_system_a: 800000
(bootloader) partition-type:vbmeta_system_a: raw data
(bootloader) partition-size:vbmeta_a: 800000
(bootloader) partition-type:vbmeta_a: raw data
(bootloader) partition-size:tee_a: 800000
(bootloader) partition-type:tee_a: raw data
(bootloader) partition-size:dtbo_a: 800000
(bootloader) partition-type:dtbo_a: raw data
(bootloader) partition-size:vendor_boot_a: 4000000
(bootloader) partition-type:vendor_boot_a: raw data
(bootloader) partition-size:boot_a: 2000000
(bootloader) partition-type:boot_a: raw data
(bootloader) partition-size:lk_a: 100000
(bootloader) partition-type:lk_a: raw data
(bootloader) partition-size:gz_a: 1000000
(bootloader) partition-type:gz_a: raw data
(bootloader) partition-size:sspm_a: 100000
(bootloader) partition-type:sspm_a: raw data
(bootloader) partition-size:scp_a: 100000
(bootloader) partition-type:scp_a: raw data
(bootloader) partition-size:spmfw_a: 100000
(bootloader) partition-type:spmfw_a: raw data
(bootloader) partition-size:md1img_a: 6400000
(bootloader) partition-type:md1img_a: raw data
(bootloader) partition-size:logo: b00000
(bootloader) partition-type:logo: raw data
(bootloader) partition-size:nvram: 4000000
(bootloader) partition-type:nvram: raw data
(bootloader) partition-size:proinfo: 300000
(bootloader) partition-type:proinfo: raw data
(bootloader) partition-size:sec1: 200000
(bootloader) partition-type:sec1: raw data
(bootloader) partition-size:seccfg: 800000
(bootloader) partition-type:seccfg: raw data
(bootloader) partition-size:protect2: ade000
(bootloader) partition-type:protect2: ext4
(bootloader) partition-size:protect1: 800000
(bootloader) partition-type:protect1: ext4
(bootloader) partition-size:metadata: 2000000
(bootloader) partition-type:metadata: raw data
(bootloader) partition-size:md_udc: 169a000
(bootloader) partition-type:md_udc: ext4
(bootloader) partition-size:nvdata: 4000000
(bootloader) partition-type:nvdata: ext4
(bootloader) partition-size:nvcfg: 2000000
(bootloader) partition-type:nvcfg: ext4
(bootloader) partition-size:frp: 100000
(bootloader) partition-type:frp: raw data
(bootloader) partition-size:expdb: 1400000
(bootloader) partition-type:expdb: raw data
(bootloader) partition-size:para: 80000
(bootloader) partition-type:para: raw data
(bootloader) partition-size:boot_para: 100000
(bootloader) partition-type:boot_para: raw data
(bootloader) partition-size:pgpt: 8000
(bootloader) partition-type:pgpt: raw data
(bootloader) partition-size:preloader_b: 40000
(bootloader) partition-type:preloader_b: raw data
(bootloader) partition-size:preloader_a: 40000
(bootloader) partition-type:preloader_a: raw data
(bootloader) partition-size:preloader: 40000
(bootloader) partition-type:preloader: raw data
(bootloader) serialno: F21PMQC2511002753
(bootloader) off-mode-charge: 1
(bootloader) warranty: no
(bootloader) unlocked: yes
(bootloader) secure: no
(bootloader) kernel: lk
(bootloader) product: AGN_3224WPA_F21PRO_C3BW_MV3224_P0_V02
(bootloader) is-userspace: no
(bootloader) slot-retry-count:b: 7
(bootloader) slot-retry-count:a: 7
(bootloader) slot-unbootable:b: no
(bootloader) slot-unbootable:a: no
(bootloader) slot-successful:b: no
(bootloader) slot-successful:a: yes
(bootloader) slot-count: 2
(bootloader) current-slot: a
(bootloader) has-slot:sgpt: no
(bootloader) has-slot:flashinfo: no
(bootloader) has-slot:otp: no
(bootloader) has-slot:userdata: no
(bootloader) has-slot:super: no
(bootloader) has-slot:vbmeta_vendor: yes
(bootloader) has-slot:vbmeta_system: yes
(bootloader) has-slot:vbmeta: yes
(bootloader) has-slot:tee: yes
(bootloader) has-slot:dtbo: yes
(bootloader) has-slot:vendor_boot: yes
(bootloader) has-slot:boot: yes
(bootloader) has-slot:lk: yes
(bootloader) has-slot:gz: yes
(bootloader) has-slot:sspm: yes
(bootloader) has-slot:scp: yes
(bootloader) has-slot:spmfw: yes
(bootloader) has-slot:md1img: yes
(bootloader) has-slot:logo: no
(bootloader) has-slot:nvram: no
(bootloader) has-slot:proinfo: no
(bootloader) has-slot:sec1: no
(bootloader) has-slot:seccfg: no
(bootloader) has-slot:protect2: no
(bootloader) has-slot:protect1: no
(bootloader) has-slot:metadata: no
(bootloader) has-slot:md_udc: no
(bootloader) has-slot:nvdata: no
(bootloader) has-slot:nvcfg: no
(bootloader) has-slot:frp: no
(bootloader) has-slot:expdb: no
(bootloader) has-slot:para: no
(bootloader) has-slot:boot_para: no
(bootloader) has-slot:pgpt: no
(bootloader) has-slot:preloader: yes
(bootloader) version-baseband: MOLY.LR12A.R3.MP.V202.3
(bootloader) version-bootloader: AGN_3224WPA_F21PRO_C3BW_MV3224_P0_V02-9
(bootloader) version-preloader:
(bootloader) version: 0.5
all: Done!!
Finished. Total time: 0.007s
(venv) @P9:~$ mtk printgpt
MTK Flash/Exploit Client Public V2.0.1 (c) B.Kerler 2018-2024
Preloader - Status: Waiting for PreLoader VCOM, please reconnect mobile to brom mode
Port - Device detected :)
Preloader - CPU: MT6761/MT6762/MT3369/MT8766B(Helio A20/P22/A22/A25/G25)
Preloader - HW version: 0x0
Preloader - WDT: 0x10007000
Preloader - Uart: 0x11002000
Preloader - Brom payload addr: 0x100a00
Preloader - DA payload addr: 0x201000
Preloader - CQ_DMA addr: 0x10212000
Preloader - Var1: 0x25
Preloader - Disabling Watchdog...
Preloader - HW code: 0x717
Preloader - Target config: 0x0
Preloader - SBC enabled: False
Preloader - SLA enabled: False
Preloader - DAA enabled: False
Preloader - SWJTAG enabled: False
Preloader - EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: False
Preloader - Root cert required: False
Preloader - Mem read auth: False
Preloader - Mem write auth: False
Preloader - Cmd 0xC8 blocked: False
Preloader - Get Target info
Preloader - HW subcode: 0x8a00
Preloader - HW Ver: 0xca01
Preloader - SW Ver: 0x200
Preloader - ME_ID: 070D599DF78F545DFA39C1C9F36B0DFF
Preloader - SOC_ID: FDBF976F7819C5F31892CC46A69C004EF79CF0D58B662841911232C5D397EB05
DaHandler - Device is unprotected.
DaHandler - Device is in Preloader-Mode.
DAXFlash - Uploading xflash stage 1 from MTK_DA_V5.bin
XFlashExt - Patching da1 ...
Mtk - Patched "Patched loader msg" in preloader
Mtk - Patched "hash_check" in preloader
Mtk - Patched "get_vfy_policy" in preloader
XFlashExt - Patching da2 ...
XFlashExt - Security check patched
XFlashExt - DA version anti-rollback patched
XFlashExt - SBC patched to be disabled
XFlashExt - Register read/write not allowed patched
DAXFlash - Successfully uploaded stage 1, jumping ..
Preloader - Jumping to 0x200000
Preloader - Jumping to 0x200000: ok.
DAXFlash - Successfully received DA sync
DAXFlash - Uploading stage 2...
DAXFlash - Upload data was accepted. Jumping to stage 2...
DAXFlash - Boot to succeeded.
DAXFlash - Successfully uploaded stage 2
DAXFlash - DA SLA is disabled
DAXFlash - EMMC FWVer: 0x0
DAXFlash - EMMC ID: GD6BMB
DAXFlash - EMMC CID: 150100474436424d420145b4063c156f
DAXFlash - EMMC Boot1 Size: 0x400000
DAXFlash - EMMC Boot2 Size: 0x400000
DAXFlash - EMMC GP1 Size: 0x0
DAXFlash - EMMC GP2 Size: 0x0
DAXFlash - EMMC GP3 Size: 0x0
DAXFlash - EMMC GP4 Size: 0x0
DAXFlash - EMMC RPMB Size: 0x400000
DAXFlash - EMMC USER Size: 0x747c00000
DAXFlash - HW-CODE : 0x717
DAXFlash - HWSUB-CODE : 0x8A00
DAXFlash - HW-VERSION : 0xCA01
DAXFlash - SW-VERSION : 0x200
DAXFlash - CHIP-EVOLUTION : 0x0
DAXFlash - DA-VERSION : 1.0
DAXFlash - Extensions were accepted. Jumping to extensions...
DAXFlash - DA Extensions successfully added
GPT Table:
boot_para: Offset 0x0000000000008000, Length 0x0000000000100000
Flags 0x00000000, UUID f57ad330-39c2-4488-b09b-00cb43c9ccd4, Type EFI_BASIC_DATA
para: Offset 0x0000000000108000, Length 0x0000000000080000
Flags 0x00000000, UUID fe686d97-3544-4a41-21be-167e25b61b6f, Type EFI_BASIC_DATA
expdb: Offset 0x0000000000188000, Length 0x0000000001400000
Flags 0x00000000, UUID 1cb143a8-b1a8-4b57-51b2-945c5119e8fe, Type EFI_BASIC_DATA
frp: Offset 0x0000000001588000, Length 0x0000000000100000
Flags 0x00000000, UUID 3b9e343b-cdc8-4d7f-a69f-b6812e50ab62, Type EFI_BASIC_DATA
nvcfg: Offset 0x0000000001688000, Length 0x0000000002000000
Flags 0x00000000, UUID 5f6a2c79-6617-4b85-02ac-c2975a14d2d7, Type EFI_BASIC_DATA
nvdata: Offset 0x0000000003688000, Length 0x0000000004000000
Flags 0x00000000, UUID 4ae2050b-5db5-4ff7-d3aa-5730534be63d, Type EFI_BASIC_DATA
md_udc: Offset 0x0000000007688000, Length 0x000000000169a000
Flags 0x00000000, UUID 1f9b0939-e16b-4bc9-bca5-dc2ee969d801, Type EFI_BASIC_DATA
metadata: Offset 0x0000000008d22000, Length 0x0000000002000000
Flags 0x00000000, UUID d722c721-0dee-4cb8-838a-2c63cd1393c7, Type EFI_BASIC_DATA
protect1: Offset 0x000000000ad22000, Length 0x0000000000800000
Flags 0x00000000, UUID e02179a8-ceb5-48a9-3188-4f1c9c5a8695, Type EFI_BASIC_DATA
protect2: Offset 0x000000000b522000, Length 0x0000000000ade000
Flags 0x00000000, UUID 84b09a81-fad2-41ac-0e89-407c24975e74, Type EFI_BASIC_DATA
seccfg: Offset 0x000000000c000000, Length 0x0000000000800000
Flags 0x00000000, UUID e8f0a5ef-8d1b-42ea-2a9c-835cd77de363, Type EFI_BASIC_DATA
sec1: Offset 0x000000000c800000, Length 0x0000000000200000
Flags 0x00000000, UUID d5f0e175-a6e1-4db7-c094-f82ad032950b, Type EFI_BASIC_DATA
proinfo: Offset 0x000000000ca00000, Length 0x0000000000300000
Flags 0x00000000, UUID 1d9056e1-e139-4fca-0b8c-b75fd74d81c6, Type EFI_BASIC_DATA
nvram: Offset 0x000000000cd00000, Length 0x0000000004000000
Flags 0x00000000, UUID 7792210b-b6a8-45d5-91ad-3361ed14c608, Type EFI_BASIC_DATA
logo: Offset 0x0000000010d00000, Length 0x0000000000b00000
Flags 0x00000000, UUID 138a6db9-1032-451d-e991-0fa38ff94fbb, Type EFI_BASIC_DATA
md1img_a: Offset 0x0000000011800000, Length 0x0000000006400000
Flags 0x00000000, UUID 756d934c-50e3-4c91-46af-02d824169ca7, Type EFI_BASIC_DATA
spmfw_a: Offset 0x0000000017c00000, Length 0x0000000000100000
Flags 0x00000000, UUID a3f3c267-5521-42dd-24a7-3bdec20c7c6f, Type EFI_BASIC_DATA
scp_a: Offset 0x0000000017d00000, Length 0x0000000000100000
Flags 0x00000000, UUID 8c68cd2a-ccc9-4c5d-578b-34ae9b2dd481, Type EFI_BASIC_DATA
sspm_a: Offset 0x0000000017e00000, Length 0x0000000000100000
Flags 0x00000000, UUID 6a5cebf8-54a7-4b89-1d8d-c5eb140b095b, Type EFI_BASIC_DATA
gz_a: Offset 0x0000000017f00000, Length 0x0000000001000000
Flags 0x00000000, UUID a0d65bf8-e8de-4107-3494-1d318c843d37, Type EFI_BASIC_DATA
lk_a: Offset 0x0000000018f00000, Length 0x0000000000100000
Flags 0x00000000, UUID 46f0c0bb-f227-4eb6-2fb8-66408e13e36d, Type EFI_BASIC_DATA
boot_a: Offset 0x0000000019000000, Length 0x0000000002000000
Flags 0x00000000, UUID fbc2c131-6392-4217-1eb5-548a6edb03d0, Type EFI_BASIC_DATA
vendor_boot_a: Offset 0x000000001b000000, Length 0x0000000004000000
Flags 0x00000000, UUID e195a981-e285-4734-2580-ec323e9589d9, Type EFI_BASIC_DATA
dtbo_a: Offset 0x000000001f000000, Length 0x0000000000800000
Flags 0x00000000, UUID e29052f8-5d3a-4e97-b5ad-5f312ce6610a, Type EFI_BASIC_DATA
tee_a: Offset 0x000000001f800000, Length 0x0000000000800000
Flags 0x00000000, UUID 9c3cabd7-a35d-4b45-578c-b80775426b35, Type EFI_BASIC_DATA
vbmeta_a: Offset 0x0000000020000000, Length 0x0000000000800000
Flags 0x00000000, UUID e7099731-95a6-45a6-e5a1-1b6aba032cf1, Type EFI_BASIC_DATA
vbmeta_system_a: Offset 0x0000000020800000, Length 0x0000000000800000
Flags 0x00000000, UUID 8273e1ab-846f-4468-99b9-ee2ea8e50a16, Type EFI_BASIC_DATA
vbmeta_vendor_a: Offset 0x0000000021000000, Length 0x0000000000800000
Flags 0x00000000, UUID d26472f1-9ebc-421d-14ba-311296457c90, Type EFI_BASIC_DATA
md1img_b: Offset 0x0000000021800000, Length 0x0000000006400000
Flags 0x00000000, UUID b72ccbe9-2055-46f4-67a1-4a069c201738, Type EFI_BASIC_DATA
spmfw_b: Offset 0x0000000027c00000, Length 0x0000000000100000
Flags 0x00000000, UUID 9c1520f3-c2c5-4b89-4282-fe4c61208a9e, Type EFI_BASIC_DATA
scp_b: Offset 0x0000000027d00000, Length 0x0000000000100000
Flags 0x00000000, UUID 902d5f3f-434a-4de7-8889-321e88c9b8aa, Type EFI_BASIC_DATA
sspm_b: Offset 0x0000000027e00000, Length 0x0000000000100000
Flags 0x00000000, UUID bece74c8-d8e2-4863-fe9b-5b0b66bb920f, Type EFI_BASIC_DATA
gz_b: Offset 0x0000000027f00000, Length 0x0000000001000000
Flags 0x00000000, UUID ff1342cf-b7be-44d5-5ea2-a435addd2702, Type EFI_BASIC_DATA
lk_b: Offset 0x0000000028f00000, Length 0x0000000000100000
Flags 0x00000000, UUID a4da8f1b-fe07-433b-cb95-84a5f23e477b, Type EFI_BASIC_DATA
boot_b: Offset 0x0000000029000000, Length 0x0000000002000000
Flags 0x00000000, UUID c2635e15-61aa-454e-409c-ebe1bdf19b9b, Type EFI_BASIC_DATA
vendor_boot_b: Offset 0x000000002b000000, Length 0x0000000004000000
Flags 0x00000000, UUID 4d2d1290-36a3-4f5d-b4af-319f8ab6dcd8, Type EFI_BASIC_DATA
dtbo_b: Offset 0x000000002f000000, Length 0x0000000000800000
Flags 0x00000000, UUID fdce12f0-a7eb-40f7-5083-960972e6cb57, Type EFI_BASIC_DATA
tee_b: Offset 0x000000002f800000, Length 0x0000000000800000
Flags 0x00000000, UUID 0fbbafa2-4aa9-4490-8389-5329328505fd, Type EFI_BASIC_DATA
super: Offset 0x0000000030000000, Length 0x00000000e0000000
Flags 0x00000000, UUID a76e4b2f-31cb-40ba-6a82-c0cb0b73c856, Type EFI_BASIC_DATA
vbmeta_b: Offset 0x0000000110000000, Length 0x0000000000800000
Flags 0x00000000, UUID f54ac030-7004-4d02-8194-bbf982036807, Type EFI_BASIC_DATA
vbmeta_system_b: Offset 0x0000000110800000, Length 0x0000000000800000
Flags 0x00000000, UUID c4c310e2-4a7e-77d3-1848-61e2d8bb5e86, Type EFI_BASIC_DATA
vbmeta_vendor_b: Offset 0x0000000111000000, Length 0x0000000000800000
Flags 0x00000000, UUID 3734710f-0f13-1ab9-4c73-12a08ec50837, Type EFI_BASIC_DATA
userdata: Offset 0x0000000111800000, Length 0x00000006328f8000
Flags 0x00000000, UUID 85a5b02f-3773-18b3-4910-718cde95107e, Type EFI_BASIC_DATA
otp: Offset 0x00000007440f8000, Length 0x0000000002b00000
Flags 0x00000000, UUID 6fce83a6-5273-4748-4511-c205ebb4b8ad, Type EFI_BASIC_DATA
flashinfo: Offset 0x0000000746bf8000, Length 0x0000000001000000
Flags 0x00000000, UUID 3645e6a3-a7e3-19b2-4149-172c10190eef, Type EFI_BASIC_DATA
Total disk size:0x0000000747c00000, sectors:0x0000000003a3e000
(venv) P9:~$
EDIT: It appears to be the new one. why dont i see a device admin and i have adb access
the new one has adb accses just you can use adb install or pm install and most if not all pm commands fail. i havent been able to find a device admin on mine either so dont know. but you most definetly have a new qin v3 based on the s/n (chekc the charger port if it is orange)
heres a super with working gapps - PLEASE HELP with new version qin F21, different hardware and ROM - #605 by dfrydman
heres a working twrp PLEASE HELP with new version qin F21, different hardware and ROM - #603 by dfrydman
This one caused a boot loop
Yikes ! Iâm going to try to see if I can get it to work. Any advice?
it worked for me - did you flash the 3.0.2 rom i posted in that thread. maybe the boot images are different than the stock one.
Thatâs what their phone is running stock, I didnât change anything I just flashed the boot_a
Will it work with
does the stock have google apps
are you using this rom PLEASE HELP with new version qin F21, different hardware and ROM - #166 by dfrydman
Yes
No, is that any different than stock ?
yes. flash that one it has no gapps - you can use my super i posted earlier if you want gapps and my twrp boot image should work for this rom
I just flashed it and it seemed to work
(The bands show up in engineering mode)
when you put an sim card in it wont register with any tower. but it could be they made it intentionally like that as @william said so maybe we can reverse it
Why in the world would the purposely make it that they canât sell devices in certain places?
