@william was saying it might be because of their aggreement with the f30 sellers
the modem is the same - as the old version - confirmed using claude
so maybe we can reverse the software changes and make them work in the us
@ars18 can you upload this super to V3 as a Gapps super
Also can we upload the stock for V3
My serial number: F21PMQC251200****
F21 Pro V.3 - 3/32 version
Got a GitHub handle?
Anyone have stock firmware for V2?
Just use 1.0.8 it works
Without any bugs?
SpeakerâŚ
@A.I.V It will not have the speaker bug when flashing with format and download ( that is the way I always fixed the speaker issue by just flashing 1.0.8)
That doesnât make sense ![]()
Also you gotta reflash identifier partitions then after
Try it it works
Donât have one to test. But the boot and dtbo in 1.0.8 are old and there is no new speaker firmware in vendor.
But you formatted everything
Itâs different hardware! Why does that matter
Youâre right no clue but I never had an issue
I think you have an old one ![]()
Iâve had many different ones some had the issue and I always just flashed 1.0.8 and it fixed the problem
When you say stock you mean signed?
