Yes
I was asking @A.I.V
U trying to unbrick a phone? What’s the goal?
Yes, I mean signed.
Currently, I havn’t broken phone. but, I want that I can to fix.
I would just either pull your current firmware and resign it, then it can be flashed with spflash, or patch one of the older firmware like 1.0.8 to work with V2 and sign it.
Replace images in signed package and use original scatter.
Both guides available on the forum.
https://forums.jtechforums.org/t/guide-fix-new-batch-f21-pro-speaker-issue
https://forums.jtechforums.org/t/lock-bootloader-with-custom-firmware
Then upload for ppl to use ![]()
is there a definitive way of knowing from a serial number? the “ultimate guide” only shows one new serial number…
i want to buy 3/32 and i want to know which version to buy to be able to flash it
i can buy PC25 or MQ25 which one???
and also is threre any Other version except the PL that is possible to flash?
what do you mean you can buy “i can buy PC25 or MQ25 which one???“
you found a seller for the PC or PL version
Where is everyone buying their F21s these days?
New version or old?
It’s very hard to get the old version you have to have to seller to send you the serial number and if it’s the old version hope that he ships you that one
New. I need a new one for my lineageos project.
Aliexpress
@dfrydman is looking to get rid of some of the new version type
@FlipAdmin I have brand new - new version of qins I would sell for much cheaper than online.
you can contact me if you want at 281-691-2421
Model: Qin AI Life F21 Pro
Serial prefix: F21PL24 (full serial available if needed)
Storage: 4 GB / 64 GB
Blue USB port
Purchased in Israel
Flashed 3.0.2 GApps with SP Flash Tool and received STATUS_SEC_IMG_TYPE_MISMATCH. Phone now bootloops in preloader. MTKClient reports SBC=False, SLA=False, DAA=False and can detect the MT6761 when it connects. Which stock firmware should I restore?
any ideas or leads
I just picked up this qin from alibaba, not sure what version it is, i am unable to enter brom, just the preloader. It has an orange usb port but old boot image.
the red port…
sorry the coloring in the photo is wrong, its orange
same thing. those need signed da’s. @0xB0 has it all btw
