IRIS Easy Flip 2 - 5G Flip Phone
Wow crazy, it really doesn’t even need a filter… But let me know when you tested it if it works. Its likely just a at&t thing that it doesn’t appear in the settings
Says a lot of those type of stuff in developer options (like 5G and NFC) even if the phone doesn’t support it
~$ fastboot flashing unlock
(bootloader) Press the Volume UP/Down buttons to select Yes or No.
(bootloader) Yes (Volume UP or Volume Down): Unlock(may void warranty).
(bootloader) No  (Auto exit after 5 seconds): Do not unlock bootloader.
(bootloader) Start unlock flow
(bootloader) Please Implement check key function
FAILED (remote: 'Unlock key verify failed')
fastboot: error: Command failed
They have not uploaded any fw to their server yet… and chances are when they do it will be incremental.
Found alot of other random devices though, none that anyone would be interested in.
Tell me anyway
Where do I see their firmware files?
Random lenovo tab for example
https://cdn.redstone.net.cn/Uploads/pkg/101812/288055/1739439595677.zip?auth_key=1740117924-0-0-e7250da845ca0a7d770fe86e996902e3
in ur terminal :slight_smile:
or here with ur login info :slight_smile:
https://fotana.redstoneota.com:8181/Home/Index/login?language=en-us
I’m just messing with u
Like I said, launcher is whitelisted…
But, one slot was never used, com.pri.featurephone.ai .
You can create any app with that package name and it will show up as #7 in tools.
I made a simple app list launcher
Here’s the slot:
<item>com.pri.featurephone.ai/com.pri.featurephone.ai.AiAssistantActivity</item>
Unfortunately for you google told me not to go to that link
No info for
you
you
you
you
Meh
Anyway I see you put service on it
So tell me, hotspot works? Visual Voicemail? Call Recorder? Message+? Wi-Fi calling[1]? Jtech App[2]?
  1. yea this won’t work on at&t and its mvnos ↩︎
  2. super important for jtech users ↩︎
Interestingly enough, it will have the same compression issues as the rest of the lot once unlocked.
Has same default profile and ua
device is pure ARM32 userspace
Working on a root exploit. Dunno how it will go.
Update: no dice, no root, no exploit, nada.
Best I got was learning I can put whatever I want in tools as #7
did you try sp, shorting into brom and cm2 dongle?
Any hope?
Do you recommend this phone?
Doesn’t have the DA (yet)
Review incoming.
Finally the first one to do it, can’t wait!
My thoughts:
I think @ys770 said 30 days to unlock, which already makes it more worthwhile. @ys770 (yes, I know I tagged you twice), does it auto unlock?
And here’s an app list launcher that appears in tools #7, was more of a yolo POC, can definitely be hardened and improved.
App List_1.0.apk (2.5 MB)
Long press to pin an app to the top.
Any installed app can be made to show under tools #7, if the source is wanted lemme know and I’ll push it (again, just a POC, did not spend time on hardening or features).
That’s the open slot. All others are populated.
Pretty sure that’s what I was told when I called them
We shall see. Don’t remember when I activated mine.
Probably sometime around this post:
We need a remind me bot like reddit :slight_smile:
