Kyocera Phones Master Thread
My opinion E4810 because the cadence and the E4610 have MMS issues (there is a fix for this on the forums just it didn’t work for me)
@ars18 can upload the one I use if you need it works great the only issue is notifications don’t show up on the main screen only on the top ( maybe now that we have root we can systemize message plus to work fully functionally?)
Sure, please upload. Thanks
Just go to app settings and clear data.
Message settings will be reset, but conversations will be saved.
Can anyone confirm this is latest?
E4810]
version=1.603VZ.0200.a
mine says latest and its 1.603VZ
Yes I finally put in the code they sent me. They didn’t send it as soon as they said, but it did unlock the phone and it works. Thanks again for your help!
What does tag use for the e4810 an mdm or custom rom?
Custom
Any good stock or finanicing apps for the e4810?
is there hope for android auto for the e4810 now?
Go for it, thought about doing it, I think it will be too slow.
I’m going to try to get another one to test it on…
I have a Kyocera e4831 that I got from tag Lkwd using Verizon through Tracphone. At first everything worked other than receiving texts and now suddenly the whole service doesn’t work… any idea what to do?
Anyone that has gotten Davx5 to work on the E4811 Xtreme+? Lmk. Thanks!
@ars18 If i get a kyocera that is boot-looping (lets say from ebay) is it always possible to fix it?
Did you try factory resetting it?
I didnt get it yet, although i want to… but i want to know if there is a way to get it working if i do get it.
like is there anything i should ask the seller…
If its just boot looping and not bricked, a factory reset is very likely to fix it
I would ask the seller if they tried factory resetting it but they might bring up the price for it if it fixed it, so shh :shushing_face: and take the discount
