Yes. Verizon prepaid.
Try your sim in another phone, if you don’t have those issues its your phone, not your service.
Which Android version is the Cadence?
Does OldMDM work on it?
I think 7.1
Are you sure?
The DuraXV e4610 is 7.1.
Cadence is 7.1.1
Anyone who has the Kyocera duraxv4520, does it run android? If yes does it have adb and can have apk’s installed?
Thats an old 3g model you are talking about. maybe you meant a different one?
If you are talking about that one, according to Chat GPT, most ran “Qualcomm BREW”
Yea I’m talking about that one, I also asked Chat GPT about it, but they also say that the cadence runs on that so there not reliable, its probably not Android though
Its not android. Curious why a 3g phone is of interest to you?
In regards to chat GPT it depends on how you ask it…
I wasn’t sure if its just 3G (And not 4G), ChatGPT also told me that it runs on 4G VoLTE but I knew that wasn’t true. I was just wondering about it not planning to buy it
If you’re asking AI for information, use Perplexity.
It has the best web integration, meaning that it will check up the most information online to answer whatever you ask it.
Half of the things I used to ask Google or ChatGPT/Gemini I now ask Perplexity.
I just asked Perplexity, and after a little back and forth, Perplexity got things a lot better than ChatGPT.
No, the Kyocera DuraXV 4520 runs Brew, not Android.
https://www.perplexity.ai/search/does-the-kyocera-duraxv-4520-r-uT7SiNpITFmfsiYVXWRpOw#2
I have the E4610 and a few days ago WIFI and Bluetooth stopped working after giving the logs from my phone to AI it told me that the drivers are missing and my only option is to factory reset the device, so I did, but it didn’t help.
Is there any way I can fix this issue? Can anybody please help me?
4 posts were split to a new topic: MDM for Kyocera e4610?
Wait, this mdm works on the Kyoceras? Even e4810?
It’s safe to uninstall the video player from a Kyocera e4610?
Ye
Hey ive been using the kyocera e4810 in israel for the last 2 plus years with trippletel and its been great.
recently my phone started shutting off randomly so i decided to buy a new one this time the e4610, i liked the smaller size.
Lmaiseh the messenger app is receiving messages from my contacts without reconizing them and writing the number as +972845…. instead of +1845…. which means i cant reply on the thread and have to open new thread to reply to +1845…. this is very annoying and i didnt have it with my e4810. If anyone can help me with a solution ill be very happy to hear thanks.
Not a solution to your problem but Israel is shutting off 2G and 3G on December 31. I dont know much about the E4610 so correct me if im wrong but if your not getting 4G (but 2G & 3G only) there now then just know what might happen
