I spoke with tripletel several times about this issue, and it’s not able to fixed-at least on message+. You could try by installing a different messaging app.
The phone has 4G network when on standby, when on a call it switches to 3G. When 3G is being discontinued the calls will automatically stay on 4G.
thanks for validating that this is an issue and that your aware of it. what are my options for downloading a different message app
See ‘uploaded apps thread’ for several D-pad compatible messaging apps.
I just checked the bands from the Kyocera E4610 and which bands Israel uses, and non of the Kyocera E4610’s 4G-LTE bands are used in Israel, are you sure your getting real 4G?
Not using E4610 anymore -cause of message thread problems, but pretty sure I used to have.
hello, my kyocera kyf42 just started bootlooping, anyone know what i can do? or does anyone have the stock firmware for the kyf42 that i could use to flash?
100 features won’t help when your phone breaks.
Stop replacing. Start keeping.
Are they trying to rip on certain higher end kosher phones?
No cuz it has many gold labels and logos so it’s obviously better…
One big difference is 4811 doesn’t have XT9 texting, 4810 still does. I would be very interested if 4811 came out with XT9 again. Here’s a Trick I use with my 4810 to make the texting usable. The message app opens very slowly sometimes, so just cancel out with the clear button when you’re done texting instead of closing the phone, and next time it will open just like it should.
Welcome
why dont you use Message+ ?
I tried that, but it had problems with scrolling up to past messages, it wouldn’t let me.
I was never able to install message plus on 4810. I wish I could though, because it’s better. I also wish I had a good option for a Kyocera AT& T phone with XT9. 4830 has prediction. Any ideas? 4710 is a nice phone, but I understand there’s no good way to filter them?
What didn’t work with installing it?
I guess I never tried message plus, though I did try another messaging app, and it just kept on crashing. Does it work for you?
Never had that issue using for a long time already
