Whats this for?
A nice guide for setting up the TCL.
most importantly the message app that you can put in contacts. But just a apk will do both.
Though the messaging app is horrible in regards to missing random MMS’s. I did not have that issue with Google Messages.
Any fix for the call history?
UPDATE:
Being that the phone was extremely slow (probably because of GAPPS) causing phone calls to take too long to show up on my screen and the bluetooth issue it wasn’t worth using as my primary phone. I miss the pros I had using it though.
What phone you using now?
Exalt.
Never had one. are they really that great?
It is super limited compared to what l had on the TCL. But for what it has, it’s amazing!
Gapps make it very slow
I have used a TCL as my main phone for over a year at this point.
People in yeshiva have pointed out to me that it’s funny that THE flip phone guy has the most basic phone. I know if I would have any other phone, I’d probably be obsessed with it (especially a CAT or Qin). I’m currently using the 4058L running PJ3R. It’s fine.
I have:
- Darth’s Contacts
- Darth’s Call Log
- I modified the call button on the launcher to go straight to the call log)
I don’t know if he lets sharing it publicly. @Darth, do you?
- Lionscribe’s app launcher
- Lionscribe’s Hebrew Keyboard
- Run
adb shell pm grant com.android.cts.hebkey android.permission.WRITE_SECURE_SETTINGSto set it up
- Run
- NeutronScott’s vMouse2
- Install the Magisk Module through adb:
adb shell su -c magisk --install-module /sdcard/vMouse2.zip
- LSPosed+App Settings Reborn (Thanks @kosherboy) and sometimes resolution switch (Credit: ybtag) to resize apps.
- Run
adb shell pm grant com.android.cts.resolutionswitch android.permission.WRITE_SECURE_SETTINGSto set it up.
- Run
Everything else is stock. I’m fine with it.
Thanks! I just don’t know why you don’t use traditional T9?
What about getting to the home screen while on a call?
I once tried it out when it first came out. It took up a lot of space on the bottom of the screen. They might have fixed it since then. Can you send the one you use?
Oh yeah. Somebody sent me a Magisk binary that brings you home if you hold the messages button. I also have voice access mapped to the star button.
It’s a setting to switch off on screen keyboard. When it’s off it’s much better and works great
Could you please send the version you use here?
I just tried it out. I see why it’s appealing, but I’m already very used to KIKA (the default). Thanks for the suggestion!
