I definitely hear that you are used to it but it drove me nuts that you cant add words.
what is the easiest way to deactivate star and message key so can be used with buton mapper
even after being told to do nothing it still opens messages
I’ve used a guide from apps4flip forums. But I think you need to be read and write. So if you weren’t able to delete the browser I’m not sure you’ll be able to do this.
can that be why modules like not a birds home module dont work either
Not sure. Modules may work differently.
Sounds like you are having magisk issues uninstall and reinstall it
you were right see other post
