They all work well, and each have their pros and cons.
Some are completely d-pad compatible, some are mostly d-pad compatible but need a mouse for some actions.
How about you try them yourself?
I will
Iāve tried installing the E4810ās, LGās, Schok, and more on other phones and it never worked, it crashes instantly when you try to go in
And unfortunately Sunbeamās and QKSMS have too much problems to use it long term
Like?
Images are hard to view. On the sunbeam one it crashes when you try to create a new conversation, sending a picture is unreasonably hard if you do it thru the app. Scrolling can become weird. While most of the settings are d-pad friendly, there are times where it gets hard without a touch screen
Maskim their all not good for people who want their messages working smoothly. We need someone to make The Message+ app from either the Exalt , DuraXV or the Cadence work with the E4831. (The E4831 is missing Verizonās SoftKeyActivity framework, and after that who knows what else.)
While Iām not sure, I donāt think the E4831 works on verizon. So there was no reason for that to be in there I guess
Hello chiming in a bit as a Kyocera 902 user.
I found an old version of SMSDroid, however its new message to someone you dont already have on the list is a bit hard to navigate with dpad only, but the rest of the app is snappy.
I tried the ones linked here:
I feel like out of all of these the QKSMS or the SMSDroid are the best choices, neither is great but both allow to send messages to new contacts with a hassle. SMS Droid is snappier outside while just using the app.
Right now I use Quik, but it has the same problem as the rest of them for starting a new conversation, it uses a floating button.
@fliper is in middle of working on a d-pad compatible messaging app, based off of Quik.
So far nothing major, but he just started.
Nice!
@Flippy what phone you testing on
Tell me which to tryā¦
I only have an f21
Awesome that you are working on a DPAD version of QUIK. Iād be happy to test it out on the kyocera 902
Updated SunbeamSMS - hopefully fixed crash on new conversation.
Thank you for the hard work, creating a new conversation does NOT crash the app anymore. Iāll try using the app on a daily basis now and report anything other bugs I find.
I am wondering about two, minor things tho.
The first is about the app icon, it is noticibly smaller compared to other apps on my phone. I can help fixing the icon if you can provide me with its image. Iām attaching an image of how it looks so you can understand.
Secondly, Iām wondering about the MENU/BACK buttons and other buttons that take their place on different menus, would it somehow be possible to bind them to kyoceras mail/browser buttons? Thatās how the native apps do it and it would make the experience of using the app just a tad bit smoother.
Thanks again!!
Just tested this on the Sonim XP3plus 5G, finally doesnāt crash when making a new conversation, and the side buttons actually do something, excellent. Main issue I still have is selecting images/videos. Maybe you can make it that it should redirect you to the stock gallery app instead of trying to select the image/video in the messaging app itself. And in the message and conversation list, whatever message your by, it becomes entirely blue and you canāt see anything. If you can fix these two issues, then this messaging app is the best replacement for any feature phone
Here is Quik Dpad app.
Its very good for using with D-Pad, but everything is too big, scrolling in a messaging conversation is messed up too, especially if there are pictures
Could you change the package name, so that the original Quik doesnāt have to be uninstalled to install yours?
Fixed
