Hi,
does anyone have issues with getting MMS messages on the LG classic flip?
i can send MMS, but when i receive MMS it just shows that its downloading.
i bought the phone unlocked and using Verizon service
You have data?
yes
i have a friend that has the same phone, but with US mobile service. it used to work, but a few months ago, MMS stopped working
I know someone who had the same problem.
You tried calling your carrier?
i only heard of this issue with tracfone direct
Issue happens due to removing the sim and inserting into a different phone. DM for a fix.
If you switch to T-Mobile you won’t experience the issue on the classic. You can then switch back to Verizon and you won’t have the issue anymore as long as you keep the sim in your classic and don’t put it in a different phone (like @famzit mentioned the issue comes from putting it in a different phone).
Can u pls post fix here?
I had the issue with USmobile on Verizon service. They couldn’t get it to work so I switch to ATT with USMobile and now it works fine. Service where I am in Lakewood, seems to be better than Verizon.
I sold unlocked LG classics for a while many ppl who where on Verizon before or TracFone had this issue when putting their already activated sim in to the phone i think a fix is if you transfer your service to a new sim with the imei of the phone it might help but its interesting that only some ppl had the issue i my self on us mobile didn’t have the issue where as other ppl on us mobile did!
I tested that with a friend who was using Verizon service and popped my T-Mobile SIM card into his LG classic. But no luck I then tried his SIM card in an s2720 and it worked perfectly fine. It was just the LG classic that’s giving the issues and i tried every possible combination. I even tried another one or two LG Classics that had lying around in my house and it’s the same issue again. It may be like one mentioned below that specific sim card with that specific phone. I’m not sure why it’s like that but it’s definitely a bug.
Yup sounds like basic lg classic issues…
what is the fix? Thank you
i hear any other way?
Not that I know of but if you use US Mobile it should be easy.
