Mouse for Exalt
Does anyone know how to install a mouse on the LG Exalt?
You gotta give accessibility permissions and write secure settings via adb
There is no way to have mouse and voice access at the same time.
If you don’t have voice access you can install the apps4flip mouse following the instructions on the site. I would point out that it doesn’t work well on the exalt and your probably better off using voice access to navigate around on the screen.
I tried with the a4f mouse and it just froze my phone until i uninstalled it via adb
I remember having it but it didn’t function well. I guess on some it doesn’t work at all.
I have had it on the exalt, worked fine, but recently stopped working.
as far a i know u can use the accessibility app on apps 4 flip to use both simultaneously
In my experience:
You can only have both running on Kyocera, Not on LG phones.
If the mouse freezes up the phone when installed, usually uninstalling and reinstalling will fix the problem.
The mouse here works pretty good.
There is a special command that can enable both the mouse and voice access on the classic
Correct. I think if you use the accessibility app you don’t need the command (for the LG Classic not the LG Exalt).
But on the exalt you can’t use this command and you can use accessibility app but only one at a time
So I attempted to install both apps(Mouse and Voice access) and now I have a frozen screen after installing the mouse. How exactly do I uninstall the mouse via adb? to Unfreeze the device? @Flippy @anonymousfliphones
Thanks guys.
Edit. Figured it out. Thanks for the DP to uninstall.
To unfreeze the screen uninstall the app via adb
I’m assuming your using an exalt because that’s the phone that it happens to can u confirm?
Yes it’s an exalt. I don’t usually click always allow when connecting via ADB. But this time i did. So thank god for that. Ran… pm list packages
Found the package for the mouse. And un-installed.
Though i’m curios how would i allow the device access if i didn’t allow USB debugging or click always allow? As the device is frozen?
Not sure
Why can’t you take the battery out and restart it?
Didnt work. Tried. Phone was frozen after i installed the voice access and mouse.
Mouse app seems to have froze phone.
