Play Integrity Fix is Dead (Pretty Much)
Don’t know how many people that would actually affect here.
I have Android 15, not sure if it still works under 13.
Technically, I can start messing with key boxes, but at this point, I think it’s worth just getting used to it and using alternatives.
You can always modify the apk to delete the calls to the Integrity API, correct?
For apps focused on security (eg banking) I would honestly not try to modify.
Can always just use Web Apps.
Don’t care about tap to pay so I guess I’m in the clear.
Seems like the link is dead now https://github.com/chiteroman/PlayIntegrityFix.
There’s a fork that is maintained by osmosis, but honestly, I just don’t care about play integrity anymore.
Mind posting the link?
@kosherboy please post the actual module
This is the latest one I have. I got it like 3 weeks ago.
PlayIntegrityFix_v19.1.zip (124.2 KB)
@ars18 is there a point of this if it was discontinued?
Probably not.
Try fork from osmosis.
Might need to use other modules as well.
