i’m new to github. I see a a bunch of files under code. would i have to download each one separately?
Press “Code”
Then “Download ZIP”
Done thanks
Right now, is there any reason for me to use eGate over TripleU MDM?
easiest way to see is to try it. it basically lets you swipe up to go home, and right/left to go back, like on smartphones
I have no clue what files i should take
https://drive.google.com/file/d/1SE5pVXp1sLSEnbJrvzyHetNfBwjytN8i/view?usp=drivesdk
Unzip it so you see what I mean.
So, who’s ready to recompile their kernel? ![]()
I might have to give this a go (when I got time to burn).
You can pretty much run anything you want in docker… Would be amazing.
For example, DietDroid is run entirely in docker.
The last one in the kosher MDM world ![]()
(It’s the same as meshimer and gentech, but still)
Anyone has it, just do a backup with any backup app… Even file manager plus.
I don’t but I installed
[Announcement] Stepping Back Until Forums App Bug is Fixed
Hey everyone,
Right now, I’m facing an issue with the Forums app — I can’t log in due to a bug. Until that’s fixed, I won’t be able to be as present here as I’d like. If you need to reach me in the meantime, you can always email me at halachidev@gmail.com.
On the development side, my app AutoSMS Reply is already released and working well. I’m currently building a major update that will let it forward all incoming SMS messages to another phone number. Once that’s complete, I’ll be starting a brand-new project: a call recorder app.
It’s been a real pleasure contributing to this community and benefiting from all your input. Stepping away, even temporarily, feels like a loss — I’m hoping the Forums app bug gets fixed soon so we can keep going.
Use a webview like everyone else ![]()
i didn’t know my options i wasn’t active in the app build time
thanks @kosherboy for reaching out to me and solving the problem
anyone with experience how to remove the verizon MDM from the Sonim xp3800
Still has issues. For example, when clicking on a new post in an old thread, sometimes hundreds of posts long, it opens to the first post.
So I’ve been digging around a bit and actually found what looks like a full dump for the Sonim XP3800 (Verizon model) on XDA. Decided to give it a try through QFIL (Qualcomm Flash Image Loader).
I’m not really familiar with QFIL, so there’s a good chance I’m missing something basic here… but I tried flashing and got a “QSAHARA FAIL” error. ![]()
I’ll upload the dump I found, in case anyone can confirm whether it’s good — or maybe share a known working one? Could really use a second opinion.
Still learning as I go here. Appreciate any help.
https://xdaforums.com/attachments/xp3800verizonfiles-zip.6155479/
how do i set an app as default messaging app on a kyocera e4810?
You should get a popup asking you if you want to set the app as default.
actually it did
