thank you
does anyone know why some apps when installed via adb say there is no google play services but when installed via the play store work fine - qin f21 pro with flashed gapps
Signatures
this happens even when i use the apk’s from the app that i downloaded from the play store
For some things even when flashed with a gapps package it still doest work like google keep.
is your play store certified?
MWAHAHAHA
Sounds ominous.
Can someone write a clear guide, for begginers how to remove a browser from a TCL flip 2?
Iv’e been looking all over the website for how to do so, and couldn’t find any clear one.
thank you.
couldnt fully follow on that one. if someone could explain more.
Maybe explain which parts you didn’t understand
where are you holding that you got lost (meaning: where do you know till [ex. to use adb, enable debugging])
Is this one not clear?
EDIT: I just posted a guide on how to remove the browser with a modified recovery. Note that I wouldn’t necessarily call the guides I’ve posted beginner level, but they’re the only way to remove the browser and not have it come back after a factory reset. Please let me know what you need help with, and I’ll try to be of assistance.
Who’s giving out my number? Lol
I don’t mind helping people with tech, but please don’t give out my main number.
Google Voice - 330-866-0730
This way I have a choice. Thank you for coming to my Ted talk.
Nobody? I’d really like to order one
Any advice where to buy an already filtered Qin? Looking for already kosher, not DIY solution.
For those that use lsposed, this enables native call recording in Google Dialer, which I believe comes enabled by default in some other countries aside from the US.
(You can try modding the APK with lspatch if you don’t, but I dunno if that will work.)
lspatch
GitHub - LSPosed/LSPatch: LSPatch: A non-root Xposed framework extending from LSPosed · GitHub
If you changed locale and region in the build.prop to india or something, it would probably be enough to activate it without lsposed. But that would change it for all your apps, not just dialer.
Which Kyoceras have fastboot accessible?
Which one did tag spoof the update with?
